PluginConfig.xml update fields
Sun Dec 09, 2018 7:05 pm
GlennNZ offline
Struck a couple of issues which have worked around - but wonder whether is better way..
1.Using PluginPrefs.
Am using PluginPrefs['access_token'] to store read-only code generated access token.
Created from PluginConfig page, after button press.
The issue I had was the ValuesDict['access_token'] was always blank - as was generated after opening. (and access_token is blank until button press)
On closing/saving the PluginConfig window it appears from my debugging that the blank access_token was written to PluginPrefs.
I presume this is expected?
I have worked around by updating the ValuesDict to the access_token within ValidatePrefsConfigUi.
Is this the best way to deal with PluginPrefs changing via code whilst Config Window is open?
2. Updated PluginConfig field
As a continuation of above - After button press access_token is generated/returned.
Can I update the already open PluginConfig window immediately with this new code? (without closing/reopening which does display it)
Seem to think I am missing something basic here for this one??
Meanwhile... I'll flick my way through examples....
Glenn
Wed Dec 12, 2018 1:02 am
FlyingDiver online
Re: PluginConfig.xml update fields
Yes. That is exactly how valuesDict is to be used. That's not a workaround.
Glenn
First question to ask yourself - why are you displaying the access_token at all? It's read only. The original Ecobee code did that, and I took it out.
Look at the code for the Ecobee 2 account device creation. It's doing the same thing. Or go back to the original Ecobee plugin and look at the code for plugin prefs there. The PIN number field is updated in real time after a button press.
Here's the code from the button press in the config dialog (not the close dialog button):
    def request_pin(self, valuesDict, typeId, devId):
        self.temp_ecobeeAccount = EcobeeAccount(None, API_KEY, None)
        pin = self.temp_ecobeeAccount.request_pin()
        if pin:
            valuesDict["pin"] = pin
            valuesDict["authStatus"] = "PIN Request OK"
            valuesDict["authStatus"] = "PIN Request Failed"
        return valuesDict
Wed Dec 12, 2018 1:23 am
GlennNZ offline
Thanks for the detailed reply.
Follow completely, some of the code is threaded given the time it takes - so may have issue returning with 'button press' valuesDict. But at least understand the correct path!
Cheers
Glenn
Wed Dec 12, 2018 10:23 am
From the 7.0 API changes announcement (yes, we're WAAAAY behind getting this stuff integrated into the mainline docs):
Added support for valuesDict['refreshCallbackMethod'] attribute which allows plugins to specify a UI refreshing callback method that is called approximately every second for updates. The callback method has the same signature as UI button actions and can return both a modified valuesDict and errorsDict for dynamic UI updating.
And Matt goes into more detail in another post.
Wed Dec 12, 2018 2:04 pm
GlennNZ offline
Thanks for the reference
Jay - that’s even easier to implement!
Wed Dec 12, 2018 3:01 pm
Yeah, it's nice when you have longish running things that need to be represented in config dialogs, like bonjour discovery. I haven't retrofitted any of our plugins that do that sort of discovery, but at some point we'll probably do it. The Z-Wave interface uses it though for inclusion.
Wed Dec 12, 2018 10:30 pm
GlennNZ offline
Thanks Jay
Last stupid question follows
How do I programmatically change something like a ?Label - I can change Textfields easily enough - but they look relatively ugly/readonly/grey-out and not the best placement.
I see the Zwave box programmatically changes text/red etc... so must be possible...
Although perhaps you have answered this here:
viewtopic.php?f=84&t=21029&p=163707&hilit=label#p163707
Cheers
Glenn
Thu Dec 13, 2018 4:51 am
As far as I know, that's still the condition of things.
<Field id="label_wanted" type="checkbox" defaultValue="false" hidden="true"/>
<Field id="label_to_show" type="label" hidden="true" enabledBindingId="label_wanted">
    <Label>Label:</Label>
</Field>
You'll need some kind of callback or other trigger to refresh the dialog.
Thu Dec 13, 2018 7:57 am
Davie is correct. It is just the visibility of that item that is dynamic, not the actual contents of the text. That is, inside the XML there are a bunch of ConfigUI Fields with a lot of different error/status messages and each one has a unique visibleBindingId value that points to a hidden checkbox field (with each error/status caption having its own hidden checkbox used soley to be able to toggle its visibility). It is a pain, and something we hope to improve.
Fri Dec 14, 2018 12:39 am
GlennNZ offline
I ignore commenting on the 'Davie' name....
But thanks for pointers and have found works fine if using visibleBinding for separate invisible configInfo field.
Within refreshmethod setting configInfo to whatever is needed.
          <Field id="configInfo" justify='left' type="textfield" hidden='true' >
          </Field>
            <Field id="InfogenerateApp" alignwithControl='true' justify='left' type="label" fontColor="red" visibleBindingId="configInfo" visibleBindingValue="generate">
            <Label>        Generating a Wit.Ai Application....  </Label>
            </Field>
              <Field id="errGenerate" justify='left' type="label" fontColor="red" visibleBindingId="configInfo" visibleBindingValue="errGenerateExists">
            <Label>         Error Generating a Wit.Ai Application. It already Exists. Delete First.</Label>
            </Field>
                  <Field id="generateSucess" justify='left' type="label" fontColor="red" visibleBindingId="configInfo" visibleBindingValue="createsuccess">
            <Label>         Successfully Generated a Wit.Ai Application....</Label>
            </Field>
              <Field id="updating" justify='left' type="label" fontColor="red" visibleBindingId="configInfo" visibleBindingValue="update">
            <Label>         Updating Wit.Ai App this might take some time and you can close dialog.</Label>
            </Field>
              <Field id="updateComplete" justify='left' type="label" fontColor="red" visibleBindingId="configInfo" visibleBindingValue="upComplete">
            <Label>         Updating Wit.Ai App Completed Successfully.</Label>
            </Field>
                   <Field id="deleting" justify='left' type="label" fontColor="red" visibleBindingId="configInfo" visibleBindingValue="delete">
            <Label>         Deleting Wit.Ai App ....</Label>
            </Field>
            <Field id="delComplete" justify='left' type="label" fontColor="red" visibleBindingId="configInfo" visibleBindingValue="delsuccess">
            <Label>         Successfully deleted Wit.Ai App ....</Label>
            </Field>
                 <Field id="deleteerror" justify='left' type="label" fontColor="red" visibleBindingId="configInfo" visibleBindingValue="delexists">
            <Label>         Error Deleting Wit.Ai App. It doesn't seem to Exist....</Label>
            </Field>
                     <Field id="deleteerror2" justify='left' type="label" fontColor="red" visibleBindingId="configInfo" visibleBindingValue="delerr">
            <Label>         Error Deleting Wit.Ai App.  Perhaps try again?.</Label>
            </Field>
          <Field id="refreshCallbackMethod" type='textfield' hidden='true' defaultValue="UIrefreshMethod">
          </Field>
Fri Dec 14, 2018 4:50 am
Davie is my mafia name. Well, it's technically "Davie Two Donut".
Matt, we need to talk...
Fri Dec 14, 2018 9:59 am
Sorry Davie, didn't mean to dox ya.
Fri Dec 14, 2018 4:45 pm
You can't unscramble an egg, Matt. :D
