2018-08-19 00:00:14.494 Flux LED Error Error updating device: Workshop - Flux LED Strip Lights. Is the IP address correct?
2018-08-19 00:00:19.495 Flux LED Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 33, in runConcurrentThread
File "plugin.py", line 95, in updateStatus
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 518, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 648, in update_state
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 620, in query_state
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 598, in _determine_query_len
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 1017, in _send_msg
timeout: timed out
2018-08-19 00:00:19.495 Flux LED Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2018-08-19 00:00:39.502 Flux LED Error Error updating device: Workshop - Flux LED Strip Lights. Is the IP address correct?
2018-08-19 00:00:44.506 Flux LED Error Error in plugin execution runConcurrentThread:
timeout: timed out
2018-08-19 00:00:44.506 Flux LED Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2018-08-19 00:01:04.515 Flux LED Error Error updating device: Workshop - Flux LED Strip Lights. Is the IP address correct?
2018-08-19 00:01:09.519 Flux LED Error Error in plugin execution runConcurrentThread:
timeout: timed out
2018-08-19 00:01:09.519 Flux LED Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2018-08-19 00:01:29.538 Flux LED Error Error updating device: Workshop - Flux LED Strip Lights. Is the IP address correct?
jrcitizen wrote:Any update on if/how this works with five-pin controllers that support RGB +CW + WW (cool white and warm white)? A few example controllers:
https://www.amazon.co.uk/Sunix-Smart-Controller-Channels-12-24V/dp/B01J5A7ABW
https://www.amazon.co.uk/Wireless-Controller-Working-Android-Home/dp/B07BKNWRL5
https://www.amazon.co.uk/LIGHTEU-controller-smartphone-control-Compatible/dp/B074XLBZ15
stuartcolman wrote:Is the development of this plugin dead? It had so much promise as well
Flux LED Error Error updating device: Closet Light. Is the IP address correct?
