Error adding new devices
Fri Nov 23, 2018 4:33 pm
siclark offline
I have started getting the below error when I try and add a new device, and I dont seem to have my plots being updated.
INDIGOplotD buttonConfirmDeviceStatesCALLBACK: devNo 1 not found in DEVICE
INDIGOplotD buttonConfirmDeviceStatesCALLBACK: devices defined= defined DEVICE# are:0 - None; 3 - Washing machine; 5 - Twins TRV new; 4 - timer washing machine; 7 - Bedroom TRV; 6 - TwinsTRV - Valve; 8 - Bedroom TRV - Valve;
INDIGOplotD buttonConfirmDeviceStatesCALLBACK: make sure you CONFIRM select a DEVICE first
Before I try and delete all devices and start again, is there an easy way to fix? I am pretty sure I am adding in the device in the right way, ie pressing the confirm button once its setup, having scrolled down to the bottom of the screen.
thanks
Fri Nov 23, 2018 10:00 pm
Re: Error adding new devices
make sure you do confirm in the top section AFTER you select a new or existing device to be edited.
THEN select the states
could you do a print device parameters and switch on debug GENERAL and post
or you can quickly do the reset thing:
1. reset everything (bottom of menu)
2. " select configuration to restore" from 2 days ago
then try again
