Tesla Battery Gateway Plugin
A Plugin for Tesla Battery Gateway - enabling you to see everything that is happening within the Tesla App.
eg.
Grid Usage in Watts
Solar Generation in Watts
Battery Usage in Watts
Home Consumption in Watts
Potential Use Scenarios:
- Informs if Grid Connection lost - so in case of Grid outages can trigger on GridDown run Action Groups - eg. turn off devices.
Given Watts used/generated/Battery can schedule heavy items usage eg. pool pump based on current battery usage/whether fill or not
Another set of Solar Data Watts/Generated/Used etc. (Enphase Plugin - also reports this)
Further Documentation to follow - but these pictures should explain
Usage
1. Need Tesla Battery with standard Gateway
2. Set up Static IP Address for this Gateway on the same network as Indigo Server
3. Install Plugin from
https://github.com/Ghawken/TeslaBatteryPlugin/releases/
4. Go to Plugin Config - enter the Gateway IP Address
Click the Check Connection Button
If communicating - Generate Devices button will appear
Click the Generate Devices button
This will create the plugins four devices with a folder called 'Tesla Battery Gateway'
eg.
More to follow.
[Not extensively tested in all conditions as - as haven't had any negative numbers as solar generation today]
Glenn
