frankyhall wrote:@Jay - I added the plugin to the plugin store.
https://www.indigodomo.com/pluginstore/196/
Approved. Thanks for the contribution.
File "plugin.py", line 112, in runConcurrentThread
File "plugin.py", line 279, in set_device_states
KeyError: 'key logChanges not found in dict'
8 Channel Network Relay Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
8 Channel Network Relay Error Error in plugin execution runConcurrentThread:
8 Channel Network Relay Error Error in plugin execution ExecuteAction:
File "plugin.py", line 144, in actionControlDevice
KeyError: key logActions not found in dict
File "plugin.py", line 133, in actionControlDevice
Wednesday 21 Nov at 16:33:15
8 Channel Network Relay Error Error in plugin execution UiValidate:
File "plugin.py", line 59, in validateDeviceConfigUi
siclark wrote:That's awesome. I look at that and think, how do you get the wires to the devices?? Is this just that you don't (mainly) have brick walls in the US and so running new cables is easy?
There no way I'd be able to get a wire from my server rack to my hot water tank without a lot of mess.
TwitchCaptain wrote:Just for fun, you can see some photos of my setup here: https://imgur.com/a/UdJzcTp?
siclark wrote:I'm not good with electrics but could the inputs be used to detect current from a PIR, one that is already powered by the alarm panel?
