Remote temperature monitoring suggestions
Sun Nov 11, 2018 9:26 am
roussell offline
I've got a few locations around the house and yard that I need to monitor the temperature. I don't need thermostatic control, just to know what the temp is in these areas. I'm looking for something wireless and battery powered (although plug-in would work if nothing else is available) that can talk to Indigo as I would use those temp readings as triggers for various things.
I know I can build what I need with an ESP or D1 mini and a temp sensor, but time is short these days and if possible I'd just like to order what I need and set it up. Any suggestions?
Thanks in advance,
Terry
Sun Nov 11, 2018 10:46 am
Re: Remote temperature monitoring suggestions
I'm not sure of Oregon Scientific are still selling their outdoor temp sensors, but if so then those with an RFXrec433 are a pretty good combo.
Sun Nov 11, 2018 10:56 am
These are "weather resistant" - https://www.amazon.com/Oregon-Scientifi ... B000I2Q1P8
The also work with the RFPlayer if you don't want to get an RFXrec433,
Mon Nov 12, 2018 8:18 am
mat offline
Z-Wave Fibaro Universal Door & Window Sensor has a built in temperature sensor if I remember correctly. Thats battery operated.
Late 2018 mini 10.14
Mon Nov 12, 2018 8:53 am
siclark offline
You need to wire in a 1 wire temp sensor but these are cheap and tiny. The 2 combined are Probably the Quickest way to get direct zwave temperature into indigo.
Mon Nov 12, 2018 9:02 am
mat offline
I've used the 1 wire, but looks like they have been updated...
https://www.vesternet.com/z-wave-fibaro ... sor-2-gen5
Wed Nov 14, 2018 9:56 pm
mundmc offline
Just saw this. These aren’t weather resistant, but pretty inexpensive if you assign a dollar value to soldering a DHT-whatever to an ESP8266 and configuring it (which works well but takes precious time). Monoprice 115902 Z-Wave Home... https://www.amazon.com/dp/B01MRYFE90?ref=yo_pop_ma_swf
Thu Nov 15, 2018 7:14 am
roussell offline
I rummaged through my parts bin and found a few extra Sonoff basic switches and some 1-wire sensors. I flashed them with Tasmota and soldered on the temp sensors. I did everything while watching Monday night football. The sensors/switch talk MQTT to Indigo and work well. Just in time too since it’s freaking snowing in Alabama this morning!
It was “free” since I had everything laying around, but would have been less than $10USD each if I had to buy them. Probably 15 minutes each for the build and configure. I’ll post some photos of everything and give some more details later tonight.
Thu Nov 15, 2018 7:15 pm
mundmc offline
I definitely would read a tutorial (with pics)!!!
