Oh wow. These are awesome!! Included and installed in 3 mins, even across different floor from Mac. Instant response. Wish I had bought these sooner!
autolog wrote:Sorted that problem - still some tidying up to do but good progress is being made.... The plugin went into a Z-Wave loop and locked out Indigo which I eventually managed to get into to be able to stop and restart the Indigo server. ....
siclark wrote:Oh wow. These are awesome!! Included and installed in 3 mins, even across different floor from Mac. Instant response. Wish I had bought these sooner!
0x40, 0x01, 0x1F
autolog wrote:I may refine this approach once I have got everything working: with the Spirits it would be possible, for example, for the plugin to fully control them using the valve controls. I could enable the configuration to be set up to be able to specify the valve opening depending on degrees difference.
siclark wrote:I have another ten Spirits already attached to radiators.You said you have one on your desk testing, but have you got one on a radiator?
siclark wrote:I think this idea is worth pursuing because I have noticed the same thing. I will add it to the list of things to do once I have got the beta out the door.It would be cool if you could get to the point of controlling the valve directly and stop the m temperature shooting they the set point. I think the valve should start closing before the set point is reached.. ...
kw123 wrote:If the thermometer is away from the heater you will always have a delay in temp measurement. And the heater also has some capacity it will continue to heat even when it is off.
