Getting Device States in Python
Wed Nov 07, 2018 5:23 pm
teejay6 offline
I am trying to get the initial colorTemp device state for a Philips color hue bulb, change the colorTemp via script, and then return colorTemp to the initial value. I am able to change the colorTemp, but the device state value I get from bulb_name.states['colorTemp'] does not change.
Here is a script that illustrates the problem. I set the initial colorTemp to 2967. The initial bulb_name.states['colorTemp'] value = 2967. This is correct. (In fact, I get the correct bulb_name.states['colorTemp'] value on the first request every time, whether it is 2967 or any other value.)
I then set the colorTemp value to 2237. The bulb changes to 2237. The colorTemp value in the Indigo 7 app Device List updates and shows 2237. But the bulb_name.states['colorTemp'] value is still = 2967.
I then set the colorTemp value to 6410. The bulb changes to 6410. The colorTemp value in the Indigo 7 app Device List updates and shows 6410. But the bulb_name.states['colorTemp'] value is still = 2967.
I then set the colorTemp value back to 2237. The bulb changes to 2237. The colorTemp value in the Indigo 7 app Device List updates and shows 2237. But the bulb_name.states['colorTemp'] value is still = 2967.
Here is the script I have been using:
#Script to get current state of light bulb device
import time
delay_margin = 5
bulb_name = indigo.devices[345799647]
#Initial values for color temp
color_temp_initial_var = 2237
indigo.server.log("Color Temperature Initial Variable is: " + str(color_temp_initial_var))
indigo.dimmer.setColorLevels(bulb_name, 100, 100, 100, 100, 0, int(color_temp_initial_var))
time.sleep(delay_margin)
indigo.server.log("Delay in seconds: " + str(delay_margin))
#Get Initial State Values
color_temp_state = bulb_name.states['colorTemp']
indigo.server.log("Color Temperature Device State is: " + str(color_temp_state))
indigo.server.log("Delay: " + str(delay_margin))
#Set New values for color temp
color_temp_new_var = 6410
indigo.server.log("Variable Color Temperature is: " + str(color_temp_new_var))
indigo.dimmer.setColorLevels(bulb_name, 100, 100, 100, 100, 0, int(color_temp_new_var))
#Get New State Values
#Set Back to Initial values for color temp
indigo.server.log("Variable Color Temperature Initial is: " + str(color_temp_initial_var))
#Get State Values for Initial color_temp variable
indigo.server.log("Script Complete")
Here is the log output:
Action Group - Python Test 3
Script - Color Temperature Initial Variable is: 2237
Sent Hue Lights - "Lights - Office Table Lamp Left - Hue7C" on to 100 using color temperature 2237.0 K at ramp rate 0.5 sec.
Script - Delay in seconds: 5
Script - Color Temperature Device State is: 2967
Script - Delay: 5
Script - Variable Color Temperature is: 6410
Sent Hue Lights - "Lights - Office Table Lamp Left - Hue7C" on to 100 using color temperature 6410.0 K at ramp rate 0.5 sec.
Script - Variable Color Temperature Initial is: 2237
Script - Script Complete
Is there something else I need to do to get the correct device state of the colorTemp (or any of the values) after I change them in a python script? Thanks for any help.
Wed Nov 07, 2018 5:29 pm
Re: Getting Device States in Python
this
gets a copy
you need to do a refresh if you want to see the new values .. just do it again
Wed Nov 07, 2018 6:26 pm
teejay6 offline
Thanks! I added the refresh after each variable change, and it worked like a charm. I actually had a problem with the variable name I was using. I changed it to the following, and it worked better:
bulb_name = 345799647
color_temp_state = indigo.devices[int(bulb_name)].states['colorTemp']
Wed Nov 07, 2018 6:56 pm
Just a remark. Int() requires a number not a name.
Wed Nov 07, 2018 10:16 pm
teejay6 offline
OK, Thanks.
Sun Aug 30, 2020 1:45 pm
wideglidejrp offline
How can I make a list of all my devices and whether each is on or off? Something like the following...
for dev in indigo.devices.itervalues():
    indigo.server.log(dev.name, dev.onState)
John R Patrick
Author of
Home Attitude
Mon Aug 31, 2020 6:44 pm
Try:
for dev in indigo.devices.iter("indigo.sensor, indigo.relay, indigo.dimmer"):
    indigo.server.log(dev.name + u": " + unicode(dev.onState))
