Devices not updated remotely
Tue Nov 06, 2018 1:58 am
MarcoGT offline
Hi all,
I have just set up HomeKit Bridge on my father's MacMini/Indigo7.
Everything fine, except he cannot control devices from outside the network, only when iPhone is connected into the same network; setup is as follows:
- Indigo7 running on MacMini, connected via ethernet
- AppleTV connected via ethernet
- iPhone connected via WiFi
- All devices connected to the same iCloud account (even if on some devices it switches to old @mac.com address, and on some others is switches to @me.com
He has a FritzBox as modem/router, me too, and we set up a VPN between them so that I can reach all devices from inside the network.
My network is 192.168.2.x and my father's network is 192.168.1.x
Could this cause a problem? I do not think so.
On my setup, basically identical to my father, everything is working fine.
Any idea?
Tue Nov 06, 2018 5:58 am
siclark offline
Re: Devices not updated remotely
Which AppleTV does he have? Is it recent ?
Tue Nov 06, 2018 6:28 am
MarcoGT offline
ATV 4
Tue Nov 06, 2018 7:00 am
rehafer offline
Does the AppleTV show as connected in the Home? I sometimes have to log out and then back in to my iCloud account and restart the AppleTV to get it to connect.
Tue Nov 06, 2018 8:51 am
siclark offline
You also need 2FA on the iCloud account.
https://support.apple.com/en-gb/HT207057
Tue Nov 06, 2018 10:32 am
MarcoGT offline
On iPhone it is enabled; I think it is automatically enabled also on ATV
Tue Nov 06, 2018 2:25 pm
virgahyatt offline
2 Factor is an account setting. So if it's turned on all devices using that account are using it.
iCloud keychain must also be turned on for the iPhone.
If you open his home app, on the home screen click either the house or arrow in the upper left.
Look for a section labeled Home Hubs. His apple tv should be listed as connected.
If it is not then it won't be able to relay the remote commands.
If it isn't showing there, I would start by Power-Cycling his router. Also, if the vpn is setup right it shouldn't cause an issue but you might want to disconnect it to see if it makes a difference if it still isn't working after the power-cycle. The iPhone and Apple TV have to be able to detect that they are on the same network in order for the Apple TV to set itself up as the Home Hub.
Tue Nov 06, 2018 11:11 pm
MarcoGT offline
I checked in my ATV and I cannot find the 2FA setting (but I found it on my iPhone).
By the way, it showed connected both in Home App on iPhone with iOS12 both on ATV with tvOS12 but remotely nothing worked.
Therefore I suggested a factory reset of the ATV (as read on the Apple forums) but now the ATV cannot even be activated :roll: :roll:
Tue Nov 06, 2018 11:34 pm
virgahyatt offline
If it won’t activate it means it is having trouble connecting to apples activation servers and is probably related to why remote access isn’t working. To get around the activation issue connect it to a hotspot long enough to complete the setup.
Tue Nov 06, 2018 11:55 pm
MarcoGT offline
But my father told me that both process setup, manual and automatic using iPhone, network settings are never asked.
Shall I try with iPhone using LTE and not WiFi?
Wed Nov 07, 2018 8:47 am
virgahyatt offline
That’s because it’s connected via Ethernet. You will have to disconnect it to get prompted during the setup process for a WiFi connection
Thu Nov 08, 2018 1:34 am
MarcoGT offline
So, my father tried, ATV asked then for a WiFi, my father entered password, IP (no DHCP) but then it says "network not found".
I am lost now...no idea anymore.
During Christmas I will be at my parents' home and I will have a look.
My father says: "it does not work anymore since we configured the Hue hub" (which is with DHCP and connected via ETH cable)
Thu Nov 08, 2018 4:24 am
siclark offline
Can the ATV not be wired? Should be easier. Can you check that there are not static IPs set up that could bebconflicting?
Thu Nov 08, 2018 9:06 am
MarcoGT offline
It was wired when we had first problems, therefore we decided to go for WiFi :)
No IP conflicts, I checked in the router which IP are assigned
Thu Nov 08, 2018 10:14 am
virgahyatt offline
The point of taking it off of ethernet was to connect it to a different network (hotspot) so that it might be able to reach the apple activation servers. Once it's connected to that hotspot and successfully activated you can either reconnect via ethernet or connect to the normal wifi network.
As for what happened during the setup. I'm not sure what you mean by no DHCP. DHCP should be enabled on both the router and the apple tv. DHCP means that the router assigns the IP information to the devices on the network automatically. On the Apple TV, DHCP (or Automatic) tells the Apple TV to expect to get that information automatically instead of having to manually enter it all like we used to decades ago.
FYI, the Hue bridge should not have caused any issues on your network if things were setup properly.
