That works, but that node type did always work.
The Indigo mqtt node still doesn't work.
When do the superbridge topics get updated, when they change?
The indigo plugin at least needs a manual restart after having opened the config dialog.
GreenSky MQTT Bridge Debug logger debugging enabled
Started plugin "GreenSky MQTT Bridge 3.0.1"
GreenSky MQTT Bridge Debug startup called
GreenSky MQTT Bridge Debug Connected with result code 0
GreenSky MQTT Bridge Debug Subscribing to house/devices/wx030-2/level/set
GreenSky MQTT Bridge Debug set([<traceback object at 0x1055a9320>, <type 'exceptions.UnicodeDecodeError'>, UnicodeDecodeError('ascii', 'house/scenes/Alle Roll\xc3\xa4den zu copy/execute', 22, 23, 'ordinal not in range(128)')])
GreenSky MQTT Bridge Debug Started processing update for house/devices/wx010-2/deviceIsOnline.ui
GreenSky MQTT Bridge Debug json ready: {"deviceName": "wx010-2", "state": "deviceIsOnline.ui", "newValue": "Download", "oldValue": "Updated"}
GreenSky MQTT Bridge Debug Publishing new Value for house/devices/wx010-2/deviceIsOnline.ui: {"deviceName": "wx010-2", "state": "deviceIsOnline.ui", "newValue": "Download", "oldValue": "Updated"}
GreenSky MQTT Bridge Debug Message sent: house/devices/wx010-2/deviceIsOnline.ui | {"deviceName": "wx010-2", "state": "deviceIsOnline.ui", "newValue": "Download", "oldValue": "Updated"}
Started plugin "GreenSky MQTT Bridge 3.0.2"
GreenSky MQTT Bridge Debug set([<traceback object at 0x10b58c320>, <type 'exceptions.UnicodeDecodeError'>, UnicodeDecodeError('ascii', 'house/devices/Terrassent\xc3\xbcr/level/set', 24, 25, 'ordinal not in range(128)')])
GreenSky MQTT Bridge Debug Started processing update for house/devices/getDistributionInfo/deviceIsOnline.ui
GreenSky MQTT Bridge Debug json ready: {"deviceName": "getDistributionInfo", "state": "deviceIsOnline.ui", "newValue": "Download", "oldValue": "Updated"}
GreenSky MQTT Bridge Debug Publishing new Value for house/devices/getDistributionInfo/deviceIsOnline.ui: {"deviceName": "getDistributionInfo", "state": "deviceIsOnline.ui", "newValue": "Download", "oldValue": "Updated"}
GreenSky MQTT Bridge Debug Message sent: house/devices/getDistributionInfo/deviceIsOnline.ui | {"deviceName": "getDistributionInfo", "state": "deviceIsOnline.ui", "newValue": "Download", "oldValue": "Updated"}
GreenSky MQTT Bridge Debug Started processing update for house/devices/wx030-2/deviceIsOnline.ui
GreenSky MQTT Bridge Debug json ready: {"deviceName": "wx030-2", "state": "deviceIsOnline.ui", "newValue": "Download", "oldValue": "Updated"}
GreenSky MQTT Bridge Debug Publishing new Value for house/devices/wx030-2/deviceIsOnline.ui: {"deviceName": "wx030-2", "state": "deviceIsOnline.ui", "newValue": "Download", "oldValue": "Updated"}
GreenSky MQTT Bridge Debug Message sent: house/devices/wx030-2/deviceIsOnline.ui | {"deviceName": "wx030-2", "state": "deviceIsOnline.ui", "newValue": "Download", "oldValue": "Updated"}
GreenSky MQTT Bridge Debug Started processing update for house/devices/wx030-3/deviceIsOnline.ui
Gre
device names:
"Bewegungsmelder Gästeklo"
"Küche Temperatur"
"Küche Tilt/Tamper"
"Küchenfenster"
"Küchenfenster - Tamper Switch"
Action groups:
"Rolläden Küche auf"
"Rolläden Küche zu"
"Tröt"
Users browsing this forum: No registered users and 22 guests
