Hmmmmm....quad core, i7 Mac Mini Pro. Finally a mini mac computer able to run securityspy, indigo, and plex...without choking.
https://apple.news/A_JuPqUUXRbabYiAJGoj-LQ
No spam or trolling allowed -- please keep topics and posts respectful.
akimball wrote:Hmmmmm....quad core, i7 Mac Mini Pro. Finally a mini mac computer able to run securityspy, indigo, and plex...without choking.
akimball wrote:I can see where it would be an improvement. I tell you, if apple didn’t do something soon, i was going to have to stuff an iMac Pro into an equipment closet. Sacrilege.
akimball wrote:Bandwidth has become a critical factor on my 2014 mac mini since adding 12 camera’s and security spy....and now we are getting plex up and running. I was considering dual mini’s as well.
It’s not indigo. Indigo is spiffy on any mac mini. It’s media and cameras.
akimball wrote:We have two 2008 8-core mac pro’s, dual xeon quad cores I believe. Mine is early 2008 and is stuck at OS10.7.5. Wife’s is late 2008 and i think it runs 10.14, mojave. But these old beastie dragons heat the room even with the monitors turned off. So, a 30-watt mac mini pro ...coming out tomorrow... is what’s needed in our case. I have dibbs on serial number #1.
An HA system should either be on a dedicated box or as a VM. It is usually the "other things" that cause issues or the need to run the latest version of macOS. Only once have I had an issue with Indigo running as a VM. It still ran but the client couldn't connect as it kept saying that I reached the maximum number of clients. The client is only run on two machines; one was off and the other I was getting the error on. I just rebooted the VM and all was well again.
akimball wrote:Has anyone already run securityspy, indigo, and plex on one mac?
I was, when I only had two cameras. When I went to 8, SecuritySpy just killed the mini. So I moved SS and Plex to a Mac Pro I picked up used.
