Re-Add Z-Wave Motion
Sun Oct 14, 2018 6:29 am
dnomode offline
Hello Everyone,
I deleted a Z-Wave motion from my system (for testing purposes) and now Im trying to add it back and getting the following message about the Node ID
   Z-Wave                          started controller inclusion mode
   Z-Wave                          stopped controller inclusion mode
   Z-Wave Error                    the node included has the same ID as a node already in use by Indigo
   Z-Wave Error                    to change the encryption state of the device you must exclude it before re-including it
How do I get around this?
Edmond
Sun Oct 14, 2018 11:20 am
Re: Re-Add Z-Wave Motion
Try excluding it first and re-including it again.
Mon Oct 15, 2018 9:02 am
Also, are you sure you actually deleted the Indigo device that represented the sensor or did you just exclude it? If the latter, then all you need to do is edit the Indigo Device and select the new node ID in the popup at the bottom of the dialog (not create a new Indigo device).
Mon Oct 15, 2018 11:07 am
dnomode offline
I didn't exclude it, I only deleted the device from the home window of Indigo. It took a while for me to figure out how to exclude it until I found this page. https://wiki.indigodomo.com/doku.php?id ... ve_devices
The node number that was used before wasn't reused, is that normal. For example the Node was 003 - Sensor and instead of indigo using the same number after I excluded it, it used 004
Anyways, I've got it working well again.
Thanks for your help guys
Edmond
Wed Oct 17, 2018 3:25 pm
Yes, node number 3 will remain unused now until you’ve got 250 (?) nodes then it’ll cycle back to 1 and use the next unused node, ie 3.
