Steinel Z-Wave Lights
Sun May 27, 2018 4:10 pm
petematheson offline
Re: Steinel Z-Wave Lights
No worries - thanks!
Playing with a new Aeotec LED Strip right now :)
Sun May 27, 2018 4:18 pm
Ah, both 25 03 and 21 01 are supported.
Have you created a dummy Zwave Scene Controller device?
(New device > Zwave Scene Controller > Zwave Scene Controller)
Peter
Mon May 28, 2018 6:55 am
OK wow, my logs are being flooded today with this!
Z-Wave Scene Controller Debug On/Off Command received:
Z-Wave Scene Controller Debug Raw command: 01 09 00 04 00 52 03 20 01 00 82
Z-Wave Scene Controller Debug Node: 82
Z-Wave Scene Controller Debug NodeID: 82
Z-Wave Scene Controller Debug ActionRaw: 0
Z-Wave Scene Controller Debug Button: 1
Z-Wave Scene Controller Debug ActionID: 12
Z-Wave Scene Controller Debug Action: Off
Z-Wave Scene Controller Debug Updating device Driveway Flood Motion Sensor with button 1
Z-Wave Scene Controller Debug -----
Z-Wave Scene Controller Debug Node ID 82 found in controllerIDs
If I set it up for the other floodlight I get this:
Z-Wave Scene Controller Debug Node ID 85 found in controllerIDs
Both of these flooding messages disappear as soon as I remove the association on group 2.
Mon May 28, 2018 2:04 pm
Ok, try .35
https://www.dropbox.com/s/433zczkdm818t ... n.zip?dl=1
DELETE/DISABLE your dummy devices or you will continue getting full logs.
This should just log a single line for all 82/85 commands received so we can see what's happening.
Do you (now or afterwards) get any On commands from the light when you trigger motion?
Peter
Wed May 30, 2018 10:32 am
Installed the update, will check when I get home!
Do I need to keep the dummy devices enabled for it to log the information?
Wed May 30, 2018 10:37 am
Wife walked past the sensor.
I see:
0 May 2018, 17:35:25
Trigger Motion on Driveway daytime text pete
Schedule Motion on Driveway daytime text pete (delayed action)
Z-Wave Scene Controller Debug Raw Node 82 command: 01 0F 00 04 00 52 09 71 05 00 00 00 FF 07 08 00 2B
30 May 2018, 17:35:44
Z-Wave Scene Controller Debug Raw Node 82 command: 01 10 00 04 00 52 0A 71 05 00 00 00 FF 07 00 01 08 36
30 May 2018, 17:36:02
30 May 2018, 17:36:18
The light isn't set to come on during daylight (manual switch on the light itself) so it wouldn't have tried to turn the light on I believe.
Thu May 31, 2018 6:39 am
IndigoSam offline
Not related to resolving the issues you have with notification.
The device itself, what are your thoughts? Any good?
From looking through the install instructions, is it one unit or can the led part be replaced?
Sam.
Thu May 31, 2018 6:55 am
Sam.
I’m quite impressed!
It gives off good bright light, was easy to mount and connect and easy to switch on/off from Indigo. Just need to get the motion sensing working through Indigo and I can repurpose my separate motion sensors elsewhere.
It’s one unit aside from the electrics.
If only they were a bit cheaper, particularly the lights vs the flood lights
Fri Sep 21, 2018 3:01 pm
Albatros offline
Did you get the motion on/of in Indigo working and does it report lux.
Fri Sep 21, 2018 3:13 pm
Not really had time to figure out more yet. It works on motion and that’s about it. Hoping maybe 7.2 might have native support
Sun Oct 07, 2018 2:25 am
lochnesz offline
Is it better with 7.2?
Skickat från min SM-G960F via Tapatalk
Sun Oct 07, 2018 2:27 am
Didn’t see any updates in 7.2 for this light so haven’t yet upgraded!
Sun Oct 07, 2018 5:49 am
Albatros offline
Its a pity and frustrating that supporting devices takes more than a year or even they don't get supported.
- Fibaro RGBW 0-10v never supported by indigo and no plans to do it. This would give lots of opportunity to read sensor form wind, C02, Lux sensors etc. Just see how Loxone is doing that
- Steinel z-wave. Their are hardly any outside z-wave motion sensors with lux support and it is not added to 7.2. I am not getting it. Takes another year or it does not even gets supported
Besides decisions on what and what not to support. One year or not to get devices supported is not the right tempo for a domotics platform. Why not change it to every 3 months or if it is that much of work make it available for others to make device profiles. Just like homey does or Domoticz. The community can make them.
Wasn't the purpose of the license model change...
Tue Oct 09, 2018 12:46 am
lochnesz offline
As much as I like Indigo, the limited device support and the pace of adding new devices was the reason for my doubt regarding continuing my subscription. I would appreciate if adding support for more "new" devices was more prioritized.
I thought that the new subscription model would speed this up. :roll:
Tue Oct 09, 2018 9:02 am
