Home Window column resizing
Sun Oct 07, 2018 10:06 am
jstackmk offline
This is a little issue but it's been bugging me for a while. I don't see it mentioned anywhere. I just installed 7.2 and it is still there.
I have some triggers/schedules/action groups folder names that are rather long (>30 characters). If I resize the left panel of the home window I can see the full name. When I close the window and reopen, the size of the left panel stays the same but only the 1st 30 characters of the folder names are displayed with ... I can resize the panel just a little and the full name will appear. Sometimes the names will just reset to the 30 character limit without any changes to the window. Other than closing and opening the window not sure exactly what triggers this.
It is not a big issue, but an annoyance. If I am working with Indigo for a few hours, I have to do this resizing several times.
I run the Indigo client on 3 different Macs and they all have this problem (OSX versions 10.13.2 and 10.14).
Thanks much,
Jim
Sun Oct 07, 2018 11:20 am
Re: Home Window column resizing
Hi Jim,
We'll look into this.
Sun Oct 07, 2018 11:31 am
Hi Jim, can you include some screenshots of what you're describing? I can't seem to recreate but I'm also not positive I fully understand what you're talking about.
Sun Oct 07, 2018 11:57 am
I can recreate but not exactly as described. Here's a before shot:
Screen Shot 2018-10-07 at 12.50.55 PM.png (25.04 KiB) Viewed 2022 times
I then create a Trigger folder named Foobar:
Screen Shot 2018-10-07 at 12.51.16 PM.png (30.37 KiB) Viewed 2022 times
Sun Oct 07, 2018 12:42 pm
jstackmk offline
Here is the Home Window with the left column sized to reveal the entire name of the folder.
Screen Shot 2018-10-07 at 12.28.18 PM.png (121.93 KiB) Viewed 2010 times
If I quit Indigo and reopen, the column width is retained but the name is 'truncated' to about 30 characters. I need to just resize the column a bit to get the full name to display. Sometimes this occurs while Indigo is running and I need to resize the column. Not sure exactly what triggers it to 'truncate' the name while it running but it definitely occurs when I quit and reopen.
Screen Shot 2018-10-07 at 12.29.34 PM.png (128.21 KiB) Viewed 2010 times
Sun Oct 07, 2018 5:25 pm
Thanks, I've successfully recreated the issue. We'll look into it.
