ZW15RM-PLUS
Forum rules
Tue Jul 31, 2018 9:44 am
Re: ZW15RM-PLUS
Yeah, we'll look into it. I have some Neo Coolcam wallwarts that also do that and it's really annoying.
Wed Sep 05, 2018 8:51 pm
roquej offline
Re: ZW15RM-PLUS
I just installed two and they respond well. It was a breeze to associate with Indigo. However, oh brother, the log issue is very annoying!
While we wait for a permanent solution, is there no hack that we could use to stop the device from inundating the log?
JP
Thu Sep 06, 2018 7:37 am
Re: ZW15RM-PLUS
Do the device settings for that one not show the Hide state messages from Event Log checkbox? It should. If it doesn't, then re-sync it and copy/paste the Event Log window results of the sync.
Thu Sep 06, 2018 2:22 pm
roquej offline
Re: ZW15RM-PLUS
Is the same for me.
JP
Fri Sep 28, 2018 12:41 pm
Re: ZW15RM-PLUS
Indigo 7.2.0 is now available for download and should show the option to hide those Event Log messages.
Mon Apr 13, 2020 9:01 am
roquej offline
Re: ZW15RM-PLUS
I am on Indigo 7.4.1 and several of my ZW15RM-PLUS keep "storming" z-wave network with power statuses. Checked the manual and there is no command, that I can see, to stop it.
Any suggestions?
JP
Indigo PrintScreen.png (155.18 KiB) Viewed 510 times
Mon Apr 13, 2020 10:55 am
Re: ZW15RM-PLUS
Unfortunately, none other than factory resetting it to see if that helps (which is probably an exclude/re-include/re-sync). If it doesn't I would suggest contacting Enerwave to see what they say.
Mon Apr 13, 2020 3:59 pm
roquej offline
Re: ZW15RM-PLUS
Thank you, Matt. Will try that.
JP
Thu Apr 16, 2020 5:05 am
roquej offline
Re: ZW15RM-PLUS
Matt - wanted to report that excluding and re-including the device seems to have fixed the issues.
Thank you,
JP
