Micro switch with no neutral wire
Tue Sep 25, 2018 3:27 pm
dnomode offline
Hello Everyone,
I've got 2 light fixtures outside my house and I would like to control them independently. Right now both fixtures turn on with the same switch. I was thinking about using 2 Insteon Micro Switches at each of the fixtures and bypassing the switch, however I don't have a neutral wire at the fixtures. The wire running from the switch to the fixtures only has a black, white and ground.
Does anyone know if any company makes a z-wave micro switch that does not require a neutral wire?
Is there another way to wire this?
Can we use the ground as neutral? (sounds like a bad idea :| )
Thanks for the help.
Edmond
Tue Sep 25, 2018 3:40 pm
ELWOOD offline
Re: Micro switch with no neutral wire
The white wire is the neutral, so if you remove the old switch and put a mini relay switch in each light fixture you can control them separately with indigo.
Elwood
Tue Sep 25, 2018 3:49 pm
dnomode offline
Thanks Elwood, Is the mini relay switch something made by Insteon?
Would you please be able to provide me with a link to a product that would work?
Thank you
Edmond
Tue Sep 25, 2018 5:49 pm
dnomode offline
ELWOOD wrote:
Awesome, So these dimmers will work as well, correct?
https://www.smarthome.com/insteon-micro-dimmer-module-2-pack.html
And I think this is how I'll need to wire it, right?
Screenshot 2018-09-25 19.48.03.png (106.69 KiB) Viewed 1488 times
Thanks for the help
Edmond
