that is a warning... should be suppressed if rPi is disabled, will add in the next release
sudo apt-get install ethtool
sudo ethtool -s eth0 speed 100 duplex half autoneg off
piBeacon Error --------------------------------------------------------------------------------------------------------------
piBeacon Error Error in startup of plugin, waiting for 2000 secs then restarting plugin
piBeacon Error in Line '292' has error=''Plugin' object has no attribute 'pr''
self.pr = cProfile.Profile()
for d in ["Logic","DevMgmt","BeaconData","SensorData","OutputDevice","UpdateRPI","OfflineRPI","Fing","BLE","CAR","BC","all","Socket","Special","debugPlotPositions"]:
pi@raspberrypi:~/pibeacon $ 20190106-15:19:27 master IP find:::: wifiIP >><<; eth0IP: >><<; hostnameIP >>['192.168.1.185']<<; ipAddressRead >>192.168.1.185<<
20190106-15:19:40 master U.getIPNumberMaster bad IP number ... ipHostname >>['192.168.1.185']<< old from file ipAddressRead>>192.168.1.185<< not in sync with ifconfig output: wifi0IP>><<; eth0IP>>
20190106-15:19:45 master IP find:::: wifiIP >><<; eth0IP: >><<; hostnameIP >>['192.168.1.185']<<; ipAddressRead >>192.168.1.185<<
20190106-15:19:57 master U.getIPNumberMaster bad IP number ... ipHostname >>['192.168.1.185']<< old from file ipAddressRead>>192.168.1.185<< not in sync with ifconfig output: wifi0IP>><<; eth0IP>>
pi@raspberrypi:~/pibeacon $ 20190106-14:41:41 master U.getIPNumberMaster bad IP number ... ipHostname >>['192.168.1.185']<< old from file ipAddressRead>>192.168.1.185<< not in sync with ifconfig output: wifi0IP>><<; eth0IP>>
20190106-14:41:41 master rebooting / shutdown sudo killall -9 python; sudo sync;sleep 2; sudo reboot -f reboot due to no IP nummber
pi@raspberrypi:~/pibeacon $ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:c4:3e:e3 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 29 bytes 4480 (4.3 KiB)
TX packets 29 bytes 4480 (4.3 KiB)
wlan1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.185 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::ea4e:6ff:fe0c:3239 prefixlen 64 scopeid 0x20<link>
ether e8:4e:06:0c:32:39 txqueuelen 1000 (Ethernet)
RX packets 7466 bytes 2107274 (2.0 MiB)
TX packets 1357 bytes 190701 (186.2 KiB)
