ZW15RM-PLUS
Forum rules
Mon Jul 09, 2018 1:52 pm
lanbrown offline
ZW15RM-PLUS
I have a few of the Enerwave ZW15RM-PLUS outlets they work fine with Indigo even though under the supported hardware it only lists the ZW15RM.
Support wise, one addition would be nice to have. I just installed the Aeotec ZW122 and noticed that Indigo had the option not to log the temp. It would be nice to have a similar function in the ZW15RM-PLUS in that it will not log the power readings.
Mon Jul 30, 2018 9:01 pm
lanbrown offline
Re: ZW15RM-PLUS
Matt or Jay, would this be possible in a future release? This would be similar to what you have for the Aeotec sensors.
Tue Jul 31, 2018 9:44 am
Re: ZW15RM-PLUS
Yeah, we'll look into it. I have some Neo Coolcam wallwarts that also do that and it's really annoying.
Tue Jul 31, 2018 5:13 pm
lanbrown offline
Re: ZW15RM-PLUS
Yes, it is really annoying. Once I saw what you did with the Aeotec, I thought it would be handy for these as well.
Maybe you could just add the capability not to display broadcasts across all devices by adding a checkbox for every device? You know what would be easier.
Wed Sep 05, 2018 8:51 pm
roquej offline
Re: ZW15RM-PLUS
I just installed two and they respond well. It was a breeze to associate with Indigo. However, oh brother, the log issue is very annoying!
While we wait for a permanent solution, is there no hack that we could use to stop the device from inundating the log?
JP
Wed Sep 05, 2018 9:07 pm
lanbrown offline
Re: ZW15RM-PLUS
I did contact Enerwave and they said I couldn't turn off it sending the power usage updates. So there is no hack on that end. All they could suggest was to contact the Indigo devs.
Thu Sep 06, 2018 7:37 am
Re: ZW15RM-PLUS
Do the device settings for that one not show the Hide state messages from Event Log checkbox? It should. If it doesn't, then re-sync it and copy/paste the Event Log window results of the sync.
Thu Sep 06, 2018 1:56 pm
lanbrown offline
Re: ZW15RM-PLUS
It does not have that option that the Aeotec products do.
Sep 6, 2018 at 2:54:37 PM
   Z-Wave                          Syncing - started for "SD - power outlet"
   Z-Wave                          Syncing - retrieved module neighbors list: 26
   Z-Wave                          Syncing - assigning return route to "047 - SD - power outlet"
   Z-Wave                          Syncing - assigned return route
   Z-Wave                          Syncing - retrieved manufacture and model names: Enerwave - 011A, Relay Power Switch - 01110105
   Z-Wave                          Syncing - retrieved protocol version 4.24, app version 5.14
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
   Z-Wave                          Syncing - retrieved command classes: 20v1 25v1 86v1 27v1 32v3 70v1 72v1 73v1 59v1 5Av1 5Ev1 85v1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          Syncing - complete
   Z-Wave                          sent "SD - power outlet" status request
   Z-Wave                          sent "SD - power outlet" energy status request
   Z-Wave                          received "SD - power outlet" energy total to 20.7609 kWh
   Z-Wave                          received "SD - power outlet" power load to 3.997 W
Screen Shot 2018-09-06 at 2.54.09 PM.png (236.32 KiB) Viewed 820 times
Thu Sep 06, 2018 2:22 pm
roquej offline
Re: ZW15RM-PLUS
Is the same for me.
JP
Fri Sep 28, 2018 12:41 pm
Re: ZW15RM-PLUS
Indigo 7.2.0 is now available for download and should show the option to hide those Event Log messages.
Fri Sep 28, 2018 12:48 pm
lanbrown offline
Re: ZW15RM-PLUS
I'll install it later and report back in. I did see that this device was listed in the release notes and was hoping that this issue was remedied.
Fri Sep 28, 2018 2:12 pm
lanbrown offline
Re: ZW15RM-PLUS
I see that you added the option to hide the broadcast messages. I've enabled it and so far so good but probably still too early to really tell. Sometimes it would go for hours without a log message and then it was almost constant for a little while.
I had to re-sync the module and a few GE/Jasco ones as well (both fan and switch) but not all of them. I think it was only a total of six devices.
Fri Sep 28, 2018 6:11 pm
lanbrown offline
Re: ZW15RM-PLUS
Four hours and no messages in the logs. Thank you for adding full support for this device.
Sat Sep 29, 2018 12:34 pm
lanbrown offline
Re: ZW15RM-PLUS
Almost a day later and no message(s), si thank you for adding full support including being able to change the LED setup without having to manually enter raw commands.
