Fing won't show some device(s). How can I recover
Thu Aug 16, 2018 11:56 am
jtburgess offline
IP 192.168.0.10 is my Airport Express.
It used to show up properly, but since I "Reset All Devices" last week, it has disappeared.
I can see it the the fing.log:
2018/08/16 00:19:19;up;192.168.0.10;;;F0:D1:A9:0C:72:44;
but it doesn't show up when I "save ipDevices to file" or in the indigo devices window.
One other device also disappeared (a MacBook Pro). 23 other devices are behaving just fine, including another Mac, 2 iPhones, 2 iPads, etc.
How can I figure out what black hole these disappeared into and recover them?
Thu Aug 16, 2018 12:15 pm
jtburgess offline
Re: Fing won't show some device(s). How can I recover
My bad. Looks like I have a bug in an event script (from the indigo log):
  Trigger                         new device discovered
   Embedded script executor host started
   Script Error                    embedded script: 'key name FingEventDevChangedIndigoId not found in database'
   Script Error                    Exception Traceback (most recent call shown last):
     embedded script, line 3, at top level
KeyError: 'key name FingEventDevChangedIndigoId not found in database'
What variable can I use to get the indigo device ID, so I can log(email) other details about it?
PS I'm running fingscan version 7.29.31, which I believe is the latest.
Thu Aug 16, 2018 2:42 pm
posted a new version v7.29.32 on GitHub.com/kw123/fingscan (should show up in plugin store soon )
it will populate 2 variables:
ipDevsLastDevChangedIndigoName shows the indigo device NAME with last status change
FingEventDevChangedIndigoId shows the indigo device ID that triggered a finscan EVENT
hope that helps
Fri Aug 17, 2018 9:48 am
jtburgess offline
Using the indigo console, I don't see either of those variables:
>>> print indigo.variables['ipDevsLastDevChangedIndigoName']
File "<console>", line 1, in <module>
KeyError: 'key name ipDevsLastDevChangedIndigoName not found in database'
>>> print indigo.variables['FingEventDevChangedIndigoId']
I do see :
>>> print indigo.variables["ipDevsNewDeviceNo"]
description :
folderId : 1147016421
readOnly : False
remoteDisplay : True
value :
>>> print indigo.variables["ipDevsNewIPNumber"]
description :
readOnly : False
value :
which are empty at present because no event has triggered.
Is there another way to access the two variables you mentioned?
Fri Aug 17, 2018 10:01 am
Did you upgrade to the latest version
And check out the indigo variables view.
If the variables are there you can access them in a script
Good practice is
   Do your thing
except:
   Indigo.server.log(“error”)# you can be more specific
Fri Aug 17, 2018 1:38 pm
this will show the state (status) of the fingscan device that changed last
devName = indigo.variables['ipDevsLastDevChangedIndigoName'].value
if len(devName) > 0:
    dev   = indigo.devices[devName]
    state = dev.states["status"]
    indigo.server.log(state)
and this one the same for the FINGEVENT (this one uses ID not name!!)
devID = indigo.variables['FingEventDevChangedIndigoId'].value
if len(devID) > 0:
    dev   = indigo.devices[int(devID)]
Fri Aug 17, 2018 5:11 pm
jtburgess offline
Yes, I have the latest version of fingscan:
versionCheck for com.karlwachs.fingscan installed: 7.29.31
Yes I'm familiar with the variable view window. It doesn't show either of the two variables you mention, only these similar names in the "folder IP Devices": ipDevsLastUpdate, ipDevsNewDeviceNo, ipDevsNewIPNumber, ipDevsNoOfDevices.
I browsed your code. I see where you create and delete the variable 'FingEventDevChangedIndigoId'
if init:
try: indigo.variable.delete("FingEventDevChangedIndigoId")
except: pass
indigo.variable.create("FingEventDevChangedIndigoId",folder=self.FINGscanFolderID)
except: pass
I think "self." in the above is an error. FINGscanFolderID is used as a local variable in other places. I don't see it being created as an object member. That would explain why I don't see it -- it's being put into an undefined folder.
Also, I can't find any mention of 'ipDevsLastDevChangedIndigoName' in plugin.py. You must have meant one of those I listed above.
Fri Aug 17, 2018 5:45 pm
Then you likely you do not have the latest version. May be I have posted an old one.
I am out. Back in 2 hours.
Fri Aug 17, 2018 8:18 pm
indeed on the plugin store was v7.29.31 and on GitHub the latest7.29.32. sorry for that, somehow I forgot to push from GitHub to indigo store.
please download .32. the variables should all work
Sat Aug 18, 2018 8:51 pm
jtburgess... does it work for you now?
Mon Aug 20, 2018 3:27 pm
jtburgess offline
I'm now running the latest
Started plugin "fingscan 7.29.32"
and I can see both variables we've been discussing.
Now I need to rework my Actions to use the new info.
