Issue with Image
Wed Aug 08, 2018 3:21 pm
petematheson offline
Issue with Image
I'm pretty sure I'm missing something obvious here with a device image on my control pages.
Using the Honeywell Plugin, I want an Image to tell me if my heating is switched On or Off. No matter what image I use, it always uses the 'On' image, even though the heating is switched off.
I'm using systemMode from the Honeywell Evohome plugin, and currently the systemMode value shows as 'HeatingOff'
I've tried using an image with +HeatingOff on the end and still no change.
Image attached shows what an off/closed device should look like (Garage Door) as well as the text value for SystemMode and the button showing as On for heating.
Screen Shot 2018-08-08 at 22.20.54.png (29.8 KiB) Viewed 1759 times
Wed Aug 08, 2018 4:20 pm
Re: Issue with Image
Off top of my head...
Where image is whatever it’s called.
Thu Aug 09, 2018 7:56 am
So I have the images below (as I use it for multiple devices)
I'm still seeing the 'On' image, when the heating is definitely 'HeatingOff'.
Thu Aug 09, 2018 10:00 am
autolog offline
You are missing a Device1+.png image as suggested in Peter's post. :wink:
Thu Aug 09, 2018 11:02 am
RogueProeliator offline
To expand on what @autolog said -- you want to rename Device1.png (not needed) to Device1+.png (required) and the Device1+.png is what should be selected in the Control Page Editor.
Thu Aug 09, 2018 2:22 pm
Bingo, knew it was something simple. Thanks all :)
