Alexa says my devices are not responding
Fri Jul 27, 2018 3:21 pm
Barnman offline
I'm not sure where to go, since, i really don't understand how i got my Alexa to work with Indigo, lol.
I set up Alexa last Thursday, it went really smooth, and had been working. I was out of town early this week, and our internet went out. Since that anytime you ask Alexa to turn a light on or off, she just says that device is not responding.
I'm not sure if the internet going out has anything to do with it.
I had an extra router, i told my wife to swap it to see if that was bad, but later found out our ISP had an area outage.
The router, is wired to my airport express, and Alexa is on the Airport Expresses wifi. Not sure if that has anything to do with it.
I'm not really sure where to go, is there a way to resynch or do i need to start over?
Let me know what other info is needed.
Fri Jul 27, 2018 5:26 pm
Colorado4Wheeler offline
Re: Alexa says my devices are not responding
It used to pretty much all the time. Every time my Internet went down I had to reboot all my echo's. It's better now, but about 50% of the time I have to reboot them (I suspect it was a user outcry that caused Amazon to re-engineer what happens when the Internet goes down). However, that being said, it worked after a reboot every time.
Do your Airport Expresses extend a network on a more powerful wifi access point? My experience with Expresses is that they are a bit flakey if you aren't pretty close to them. I stopped accessing them for Wifi and just use them to extend a couple speakers nowadays, all my echos tie to Airport Extremes.
Fri Jul 27, 2018 5:31 pm
Barnman offline
How do you reboot Alexa? I did unplug it and plug it back in to see if that made a difference
Fri Jul 27, 2018 5:36 pm
That's how you reboot it :).
Fri Jul 27, 2018 6:02 pm
Barnman offline
I will add that in the state, it shows discovery off, on each one, i cannot figure how to get discovery on
Fri Jul 27, 2018 6:09 pm
Barnman offline
Well I got it working agin, i hit the plugin tab, and hit the reload button of the plugin, all the devices changed to discovery on, and it is working again.
Sun Jul 29, 2018 7:48 am
pbaperez offline
I had this same problem but it happened more then when the power went out. Jay suggested that a set up a scheduled restart trigger so now the Alexa plug-in restarts before we wake and before we get home. Works like a charm.
Sent from my Pixel 2 XL using Tapatalk
