Add(+) the KWh of Three Meters Together (for plotting)
Wed Jul 25, 2018 11:04 pm
kpurintun offline
I have three of the Z-wave 2 leg meters, on on each AC unit, and the other on the rest of the house. i have a split panel that allows me to do that.
I would like to add the value of each of the three devices together for whole house power usage reference, and for plotting in IndigoPlotD. I got in, set the reset schedule for once a month, then started looking around.
IndigoPlotD has the ability to "math" two things together. but I can't see how to do three. I looked at adapters. its pretty cool, but does not seem do do math between multiple devices. scripting seems to be the only way. I am not a scripter at all. I jumped in there like a little boy into the cockpit of a 747. i was fully lost.
anyone have some ideas?
Kyle
Wed Jul 25, 2018 11:49 pm
Re: Add(+) the KWh of Three Meters Together (for plotting)
Yes indigoplotd right now can add 2 data sources into one line.
Let me think about how to do 3.
Mon Jul 30, 2018 8:05 pm
### to sum up 3 energy values, put this into the action (server/execute script) of a schedule and run it once / minute
### then in variable   totalEnergy   you should have the total and that you can plot.
# replace energy1 .. with the 3 names of your devices and StateName with the name of the state that shows the energy
var1 = float(indigo.devices["energy1"]["stateName"])
var2 = float(indigo.devices["energy2"]["stateName"])
var3 = float(indigo.devices["energy3"]["stateName"])
# add it up
total = var1+var2+var3
# and format it ( eg 2345.1 )
totalText = "%.1f"% (total)
# just for .. of it log the result
indigo.server.log("total= "+ totalText)
# this varibale should already exist, and will contain the total
indigo.variable.updateValue("totalEnergy", totalText)
this should do it
