WiFi Motion Detection
Sun Jul 22, 2018 6:51 am
mundmc offline
I heard about this a while back, it’s on Amazon now: https://www.aurahome.com/
https://www.amazon.com/Aura-Home-Monito ... B0765C7NVV
It triangulated based on radio wave disruptions caused by movement.
Sun Jul 22, 2018 6:59 am
Re: WiFi Motion Detection
As originally appeared in a Cory Doctorow novel!
Sun Jul 22, 2018 8:30 am
mat offline
US only at the moment but would be interested to hear if anyone tries it.
Late 2018 mini 10.14
Sun Jul 22, 2018 10:20 am
virgahyatt offline
I checked it out and was rather disappointed. Certainly nothing even close to what was promised when they were first developing it. I had an incredibly hard time getting them to pick up any motion at all. Even getting them to connect and see each other (need at least two) was a pain, requiring that they were facing each other directly. Ended up having to use an extension cord since I didn't have any outlets on opposite ends of the house that were actually directly opposite each other. It might work better if you had more of them but I would wait and see if their next version is any better.
Sun Jul 22, 2018 6:22 pm
mundmc offline
I appreciate your sharing your experience. This sub-forum seems like it should be called “Too Good to Be True Finds.”
Mon Jul 23, 2018 1:12 am
rhanson offline
Anyone played with Xandem? There was a thread here on it, and it's about the same as this thing, except with an API. Oh, and I think it was much more expensive.
http://xandem.com/
Released for a couple years, but no reviews online, except for a video which was clearly made by a friend.
Mon Jul 23, 2018 6:23 am
...and you can’t buy it ... sold out.
Tue Jul 24, 2018 8:41 pm
mundmc offline
Karl- given your code runs the entirety of my occupancy-related Indigo functions, your rasbpi knowledge, your knowledge of existing technology (e.g. Mother), why aren't you out making millions of dollars? Your stuff is accessible and effective in a way that no other tech-start-uppy product is. Seriously, there are so many new approaches to home occupancy detection, and really no product that I know of (and please let me know if I'm wrong) has gotten it right yet. But pibeacon, with fing and unifi plugins for redundancy, is 99.99% effective for me,
Edit: I mean, talk about flexibility, your code allows me to know my mailman's phone's MAC address. That's just impressive!
Edit 2: Above with help of Security Spy and Pushover plugins.
Tue Jul 24, 2018 10:00 pm
Only UniFi cameras missing
But you have not noticed that I also know everything that happens in your home?
And thanks for the kind words. But selling the stuff would be work. And I am happy to not need to do that anymore.
Wed Jul 25, 2018 9:23 am
how about a plugin "EVENTS" where you can combine devices from different plugins that has a function like EVENTS in fingscan.
One point will be efficiency. I don't like the option for plugins to listen to all changes, but with indigo 7 you can connect plugins and they then only talk when needed ie a specific selected device changes
functions should be:
n devices create a group. the members can be managed in menus
They can be from any plugin that has the plugin-plugin communication option.
each device will have its individual timer ie delay to be active, eg if a device goes UP it will become effective immediately or after xx secs. And the same for down
then in the group of devices you will have the EVENTS : allHOME, allAWAY, atleastOneHOME, atleastOneAWAY and a counter variable nHome, nAway
+ some other options
currently fingscan does this roughly, but I would like to make it more general
any interest?
Wed Jul 25, 2018 10:02 am
[SNIP]
any interest?
This would be a great use of the pub/sub mechanism we introduced in Indigo 7. You guys (developers of plugins that do presence detection) can create an informal protocol using the pub/sub model, where you publish changes to the presence in a standard way. Then any other plugin can subscribe to those changes and do whatever.
Wed Jul 25, 2018 11:01 am
yes thats the idea !
will use something like this
in eg UNIFI/fingscan/pibeacon/... you can register /deregister a device / state to be part of the communication:
1. call other plugin to register a device/ state
"callingPlugin": "pluginName",
"deviceRegister":{"action":"register","id":id,"state":stateName,"stateOn":valueForOn,"stateOff":valueForOff}
2. de register:
"deviceRegister":{"action":"deregister","id":id,"state":stateName}
then in "EVENTS" it would (de)register new device/states
in UNIFI, once a device change occurs do a call w:
"deviceEvent":{"id":id, "state":stateName,"oldValue";old value,"newValue:newValue}
EVENTS will have threads that receive these UNIFI events where
- device / states/ values are changed and timers are set
in a EVENTS menu you can
-add/ remove these device states to groups that can trigger events
-set timer parameters for each device/state/value like repeat time gap (ie don't re-trigger away every second)
- set timers parameters for each EVENTtype (home/ away ie repeat time gap for home / away ...)
in the main loop it would do
1. loop through device states and calculate timers for each device /state / value and set internal states
2. loop through GROUPS to trigger events away / home
Wed Jul 25, 2018 12:36 pm
mundmc offline
This is intriguing and over my head, but it’s a good vector for more tinkering!
Wed Jul 25, 2018 4:10 pm
To be fair, it is based on triangulation - which requires three by definition.
If you’ve only tried with two, you don’t get anywhere near the same results.
Wed Jul 25, 2018 4:18 pm
virgahyatt offline
Oh I get that, and I didn't expect it to triangulate anything. Just provide motion/presence detection. But it couldn't even do that. I could drive my car in front of the thing and it wouldn't register it. If it had worked as expected I was going to get an additional one to try out the triangulation bit. But alas that didn't pan out.
