macOS High Sierra (10.13) FTDI Driver Bug Workaround
Fri Jul 13, 2018 2:02 pm
Re: macOS High Sierra (10.13) FTDI Driver Bug Workaround
As u have migrated everything from macro pro 2008 to mac pro 2012. I have a spare 2008... any suggestion what I should do with it?
- convert to Linux
- Convert to windows
- Keep as spare
- Sell... probably $400
Fri Jul 13, 2018 3:37 pm
Colorado4Wheeler offline
Use it for your camera server? Of course a 2008 pro is a beast and a bit noisy by todays standards, you could use it as an extra space heater.
Fri Jul 13, 2018 5:29 pm
The camera server runs in the 2012 besides indigo... And total cpu is 5%
But space heater sound good.
Fri Jul 13, 2018 6:55 pm
its only 100F, I am comfortable above 105F
Fri Jul 13, 2018 7:47 pm
That's just mean.
Sat Jul 21, 2018 11:37 am
I'm 100% High Sierra now (10.13.6) and have zero issues. Every one is upgrade path. Aeotec Gen 5 stick plugged directly into the iMac, never changes ports.
iMac (18,2) 8GB <— Production Indigo (Z-Wave only)
MacBook Pro (9,1) 8GB
MacBook Air (6,2) 8GB <— Development Indigo (no bridges)
iMac (10,1) 12 GB
The MacBook Pro is about to get Mojave.
Sun Aug 05, 2018 5:27 am
sgtwicki offline
Can you confirm which PowerLinc you're using? You mention a 2412U and a 2414U. The latter doesn't use the FTDI driver so if it doesn't work that would be a different issue.
My bad; that was a typo.
My Mojave system has a 2412U, a W800RF32 and an iButton 1-wire adapter connected. All 3 USB devices were completely non-functional (again) after the 10.13.6 update. No amount of reseating or restarting or USB hub nonsense has any effect.
Deleting the AppleUSBFTDI driver is the only solution I've found.
Sun Aug 05, 2018 10:14 am
Thanks for the confirmation. Still hoping Apple fixes the issue before Mojave ships... :roll:
Sun Aug 05, 2018 9:07 pm
gtreece offline
jay (support) wrote:
Yes, we'll install the beta at some point and test. However, the only Mac I was able to confirm the bugs on is not supported by Mojave. So, bottom line is that we may no longer have the ability to duplicate the bugs even if they persists in Mojave. Anyone who's testing Mojave would give us valuable insight into these bugs.
Jay, I have Mojave dev beta on a couple laptops, but neither are related to my Indigo setup. Is there still some testing I could do for you that would help out? The beta is running smooth enough now that I may put it on my general use Mini soon, but that is also not related to my Indigo setup at all. But I could periodically shut down my Indigo server and move hardware around for tests, if it would help.
Greg
Mon Aug 06, 2018 12:03 pm
I just reread your reply and I'm confused: you say your Mojave system but later you say 10.13.6. So, my question is have you experienced the issue with the Mojave beta?
Mon Aug 06, 2018 12:06 pm
Thanks for the offer. What we'd need to know is 1) if either one currently has the driver issue when running 10.13.x, and then 2) if the same issue occurs after you upgrade that system to Mojave. That's a non-trivial amount of work so you may not want to undertake the testing (and I totally understand).
Mon Aug 06, 2018 3:55 pm
sgtwicki offline
Grr! I keep doing that. It was remote desktop to my Mojave system, and I accidentally clicked on the "About this Mac" for my local machine instead of the remote one. :oops:
My Indigo server is running MacOS version 10.14 Beta (18A347e).
When I was running High Sierra, only the 2412U would stop responding after a random amount of time. The W800RF32 and 1-wire adapter would still continue to function. A simple restart fixed it. Once I deleted the AppleUSBFTDI.kext the problem never popped up..
On my Mojave system, it's a different story. All 3 of my USB serial devices completely fail using the Apple driver. If I delete AppleUSBFTDI.kext everything works great (and hasn't randomly disconnected either).
Mon Aug 06, 2018 5:07 pm
Dang - sounds like maybe it's actually getting worse. Sigh.
Thanks for the report. One final question: what is the exact model of your Indigo Server Mac?
Mon Aug 06, 2018 5:22 pm
sgtwicki offline
Mac Pro (early 2009). Firmware upgraded to MacPro5,1
Motherboard USB ports and generic USB 3.0 PCIe ports have same results.
Is there anything else I can do to help troubleshoot?
Tue Aug 07, 2018 9:08 am
Odd, Apple claims that only the 2010+ Mac Pros can run Mojave...
[EDIT] Never mind, I see you hacked the firmware... ;)
Page 5 of 11 1, 2, 3, 4, 5, 6, 7, 8 ... 11
