ZWave Zooz ZSE40 MultiSensor Config
Tue Jul 03, 2018 6:05 pm
ckeyes888 offline
Fairly new to Zwave but in the past, with multisensors anyway, I could always edit device prefs on the motion sensor and change
the reporting interval. On the Zooz ZSE40 Multisensor I was able to set the interval initially, but now I can't get back to the menu
that showed that option.
With my other ZWave multisensors the option is always in the device setting of the motion sensor.
Maybe someone knows how to change the interval setting on this unit?
Carl
Wed Jul 04, 2018 2:47 am
Re: ZWave Zooz ZSE40 MultiSensor Config
For multi sensors, you’ll have say 3 devices.
When you edit them, you’re actually in the same device, just on a different tab.
You can only set those WakeUp settings on the first tab, ie the main device - often motion but it depends on devices.
Wed Jul 04, 2018 8:49 am
ckeyes888 offline
Thanks. I gathered that, but the settings screen now, after it’s initial setup is quite different.
On the original screen when I first installed it, it there were options to turn off the motion sensor
and set the reporting interval.
The device settings now on the first device, the motion sensor, don’t show those anymore.
I’ll try excluding it and resetting it all up.
Carl
Wed Jul 04, 2018 9:50 am
ckeyes888 offline
Strange, even after excluding, deleting it’s devices and reinstalling I still can’t get to the menu to set
the reporting interval. It’s default seems to be about every 30 mins.
Carl
Fri Jul 13, 2018 3:45 pm
Hi Carl,
Wake the module and re-sync it in Indigo, then copy/paste the Event Log window results into a reply for me.
