- Posted on
Mon Jul 02, 2018 7:52 am
Different Computers
online
I am definitely not the guy to totally figure this out, but maybe I can ask a few questions that will help get this started.
Realize that there's a good chance that you are the only person using Indigo and this IPX800 device, so there might not be anyone who can share what they have done.
But it appears that the board is some sort of web interface to switches. Correct?
If so, then can you send a command via URL with known, included authentication? Something like
http://user:pass@192.168.0.222/relay1ON.cgi(That example is TOTALLY made up from my imagination and not at all related to any documentation I've read, because I have not read any)
If you can send commands like that, then the most simple way to do this would be to have Indigo send command line curl commands to the device. There's probably a plugin that would make this easier.
If IPX800 supports MQTT, there are plugins that make that simpler too.
