after last osx security upgrade reflector does not work
Fri Jun 15, 2018 2:51 am
getting:
 Error                           reflector connection test failed: local server unreachable
   Error                           reflector reconnection scheduled in 5 seconds
   Error                           failed to create reflector connection: local server unreachable
   Error                           check your Firewall and Network configurations and try restarting the server
   Error                           reflector reconnection scheduled in 15 minutes
also locally the iPhone can not connect to the indigo server
have osx 10.11.6, firewall is off
indigo client can connect
any suggestions?
Fri Jun 15, 2018 3:27 am
Re: after last osx security upgrade reflector does not work
Indigo's Web Server might have crashed. Try stopping/restarting the Indigo Server to see if it starts working. If it doesn't copy/paste the Event Log snippet from the server restart so I can see if there are any Web server errors.
Fri Jun 15, 2018 4:09 am
durosity offline
Reinstall indigo on the server to fix screwy permissions?
Fri Jun 15, 2018 4:59 am
Can you telnet to the port?
Daves-Air:~ Dave$ telnet 192.168.1.100 8176
Trying 192.168.1.100...
Connected to indigo-imac.localdomain.
Escape character is '^]'.
Fri Jun 15, 2018 7:08 am
reinstalling the server did it.
(rebooting .. not)
Fri Jun 15, 2018 9:42 am
I messed up the indigo web server py..
Changed a tab to 4 spaces " " in pibeacon program change web server (menu item: suppress logging of incoming change variable messages)
Did a change all tabs to " " in the pibeacon plugin program -- that also changed the tab that should have stayed a tab .
ps who ever allowed to have x spaces OR a tab in python as indent should be ... :evil: :evil: :evil:
creates so many problems
Fri Jun 15, 2018 10:47 am
THANK YOU for mentioning this. Still just learning and this indent thing is super confusing!
Fri Jun 15, 2018 11:23 am
The Python spec says an equal amount of "white space" (thank Guido for that). We're not very consistent in our stuff either, though I've been slowly standardizing to the de facto 4 spaces.
Fri Jun 15, 2018 11:29 am
durosity offline
(rebooting .. not)
Woo I’m a genius! Matt, you owe me a pay rise!
Fri Jun 15, 2018 5:41 pm
        tab = "   " # this is a real tab
        for line in f.readlines():
                    if line[0] == tab:
                        tab = u"   "  # this is a tab
                        tab = u"    " # this is 4 spaces
had this code in there
tab =" " had a tab (CTR-I) in there, but the change tabs to 4 " " spaces throughout the doc changed that and then the code went wrong ..
Sun Jun 17, 2018 3:50 pm
rehafer offline
Just had a similar problem after power glitch. I discovered that that the settings had changed from separate remote server to the all-in-1 local
