Does USB work or doesn't it?
Thu Jun 14, 2018 7:05 am
Re: Does USB work or doesn't it?
i am using that setup for some years, no issues with insteon signals.
Initially had to reboot the insteon modem some times through the zwave switch, but since I added a UBS3 card to my MacPro(2008-3,1) no issues what so ever > 1 year
On a side note.. getting a MacPro 5,1 (runs the next OSX), Will try to migrate everything over and to HighS, mainly to be able to use up to date security protocols
If that works fine, I need to decide what to do with the 2008-3,1 which is limited to elCapitan.
- sell I guess ~ $600
- convert to linux or Windows for ..??
- keep as backup
any comments / suggestions?
Thu Jun 14, 2018 10:08 am
Karl, I just ran across this. No personal experience with it, but it looks like your 3,1 is supported for moving to Sierra.
http://dosdude1.com/sierra/
Thu Jun 14, 2018 11:37 am
My production Mac is a MacPro 4,1 and still on El Capitan. I have no intention on ever moving it any further since it only runs Indigo and does that really well.
Thu Jun 14, 2018 11:41 am
What are you going to do when Indigo no longer supports El Capitan? :lol:
Thu Jun 14, 2018 12:12 pm
LOL. I suspect things will be significantly different when that happens!
Fri Jun 15, 2018 2:12 pm
durosity offline
This is what I’ve been using with my 3,1 on High Sierra. I swear it’s more stable with high Sierra than it ever was with El Capitan.. for example the built in USB ports work properly with the Z-Stick Gen 5 which it definitely didn’t before.. it’s also fixed issues with a startech PCI rs232 card I have.. and SecuritySpy was constantly dropping frames all the time.. now it’s completely sorted. I’d have said this was just due to a duff install of 10.11 originally but I’d went to the effort of wiping and reinstalling it from scratch and still had exactly the same issues.
