Z-Stick Inclusion Question
Mon Jun 11, 2018 2:06 pm
Gman34798 offline
Ok, so I have now included several nearby devices with the Z-stick plugged into the USB port. This all goes without a hitch.
Now I need to unplug and add devices that are farther away. I seem to be able to do so, as the blinking indicator shows that the device was added.
When I return to plug the Z-stick back in, boot up Indigo, the device I just added is not listed anywhere.
Am I missing a step (syncing somehow) or something?
If I unplug the Z-stick, return to the device, I can successfully exclude it, according to the LED indicator. It appears that the inclusion/exclusion process is working
but I'm confused as to why anything included doesn't show up in Indigo device browser.
Thanks for any assistance!
Mon Jun 11, 2018 2:30 pm
Gman34798 offline
Re: Z-Stick Inclusion Question
Thanks Lanbrown,
I was able to get it included after reading your post...I just had to select it to add it to Indigo...
Regarding NWI, I understand what it is, but within Indigo, is it used by default?
I'm coming from a Fibaro HCLite controller, and with their interface, I had to select "Use NWI for Inclusion" in order to enable the NWI mode.
I haven't seen Indigo ask for such an option.
Thanks again,
Greg
Mon Jun 11, 2018 2:42 pm
If you go to Indigo > Interfaces > Zwave > Start Inclusion, that is using NWI.
There's no additional question about using it; it just does by the nature of doing that sequence.
Mon Jun 11, 2018 2:45 pm
