Hi Matt,
I have just got my IRLinc and trying to set it up, but I think I am missing something in the instructions.
Can you give me (us) a simple example as to how to get it working.
David
Parp wrote:...I have some Insteon dimmers, relays, and appliance lincs linked directly to the 2411R (not going through Indigo). When I turn these items on or off with my remote, Indigo doesn't see the change in status.
yergeyj wrote:I guess the key is to select a device for the Harmony that is actually recognized (and that you don't have programmed for something else).
support wrote:Parp wrote:...I have some Insteon dimmers, relays, and appliance lincs linked directly to the 2411R (not going through Indigo). When I turn these items on or off with my remote, Indigo doesn't see the change in status.
You need to Re-Sync (via the Devices dialog) the modules that are being controlled by the IRLinc. This will tell Indigo to read the links out of those modules, which will include the new links to the IRLinc. After you do that, when Indigo sees the INSTEON command from the IRLinc it will know that those other device states need to be updated.
Regards,
Matt
support wrote:yergeyj wrote:I guess the key is to select a device for the Harmony that is actually recognized (and that you don't have programmed for something else).
Correct. I'm using the Xantech Gatekeeper IR as the Harmony remote device type, but I'm sure quite a few others will work as well.
Matt
yergeyj wrote:Unfortunately, when I press a button, Indigo recognizes it as "on" once and "off" the second time (e.g. button 1 on or button 1 off), so I need to specify links within Indigo for both on and off, as there is no way to send a specific button 1 on/off from the Harmony (that I can find), or know what state the Harmony button is in.
Users browsing this forum: No registered users and 33 guests
