How to Setup RFXCOM
Sat May 12, 2018 8:56 am
ckeyes888 offline
How to Setup RFXCOM
Hey,
Got as far as getting it communicating, I think, with some things but have no idea how to setup devices for triggers.
I see this in the log:
RFXCOM                          initializing communication on port /dev/cu.usbserial-A12HDS42 at speed 38400
   RFXCOM                          connected to RFXtrx 433.92 MHz, firmware version 24
   RFXCOM                          currently enabled receiver protocols: Oregon Scientific, X10
   RFXCOM                          enabling receiver protocols: Undecoded
   RFXCOM                          stored changed settings into non-volatile memory
   RFXCOM Error                    unknown device detected (id = 26, type = 86). Select a Wind meter from the list of devices
   RFXCOM Error                    unknown device detected (id = 971, type = 82). Select a Temperature sensor (with humidity) from the list of devices
   RFXCOM Error                    unknown device detected (id = 1549, type = 82). Select a Temperature sensor (with humidity) from the list of devices
   RFXCOM Error                    unknown device detected (id = 122, type = 85). Select a Rain sensor from the list of devices
   RFXCOM Error                    unknown device detected (id = 295, type = 82). Select a Temperature sensor (with humidity) from the list of devices
   RFXCOM Error                    unknown device detected (id = 1063, type = 82). Select a Temperature sensor (with humidity) from the list of devices
   RFXCOM Error                    unknown device detected (id = 1521, type = 82). Select a Temperature sensor (with humidity) from the list of devices
Seems to setup a device you need the channel number which I don't see in the log...maybe the id?
Also I have the X10 protocol activated but when pressing buttons on my Palm remotes nothing shows in the log.
Any help greatly appreciated!
Carl
Sat May 12, 2018 10:28 am
jalves offline
Re: How to Setup RFXCOM
Yes, the channel number is the Id.
Jeff
Sat May 12, 2018 11:54 am
... and when a device does a power off/on it changes its # :cry:
Sat May 12, 2018 1:19 pm
ckeyes888 offline
That’s not good at all.
Of my 5 OS remote temp sensors only one seems to be working.
The other devices all show temps but aren’t at all accurate to the sensors reading.
The wind direction and gust both read and change but again, aren’t at all accurate to the weather station
readings they show.
I was hoping to be able to ditch Weathersnoop, since the newer version doesn’t even support
OS weather stations anymore, but this method seems way to flaky.
Carl
Sat May 12, 2018 3:01 pm
How to Setup RFXCOM
Beside the changing number thing it is actually working very well. Long battery life and really stable
I have
3 temp/ humidity
2 pool temp
1 rain sensor
1 wind meter
Would buy them again
Fortunately the number change does not happen too often. Only when the batteries have to be replaced. ~ 1/ year .. and up to every 2 years for simple temp sensor
Sun May 13, 2018 7:39 am
ckeyes888 offline
Thinking if I could get the X10 receiver portion of it working I could retire my W800RF32
but that won’t work either.
Maybe there are better docs somewhere on how to set it up?
I’ve tried making X10 devices and sending on/off commands from my X10 remotes but they don’t update.
The log shows the received commands from the W800.
I use a number of the Palm remotes and it would seem to receive all those codes I would need
to make a device for each button?
Carl
Sun May 13, 2018 10:00 am
b_weijenberg offline
The RFXtrx433E operates at 433 MHz and US X10 operates at 310 MHz so it cannot be received.
For US X10 or US Visonic PowerCode sensors the RFXtrx315E is available. However, the US X10 sensors do not use a crystal controlled transmitter and transmit often 1 MHz lower or higher and this is outside the band limits of the RFXtrx315E.
Another option is maybe to modify the X10 sensors and replace the 310 transmitter by a 433.92 MHz transmitter.
Here an example: http://www.domotica.famschenk.eu/MS10A-433.html
Sun May 13, 2018 6:48 pm
ckeyes888 offline
Thanks. All info that I wish I knew before I bought it.
Carl
Mon May 14, 2018 9:13 am
I find that it always pays to ask questions here on the forums before buying new hardware or updating software. The collective intelligence on the forums is an awesome resource.
Tue May 15, 2018 2:30 pm
durosity offline
Even with my massive drag on it!
Can you still return the item?
Tue May 15, 2018 4:21 pm
There's always that one that totally ruins the curve...
Tue May 15, 2018 4:23 pm
durosity offline
Ruins the curve? I AM THE CURVE! I was born it in.. moulded by it. I didn’t see a straight line until I was a man.
Wait.. that sounds wrong.
Tue May 15, 2018 4:31 pm
durosity wrote:
until I was a man.
Oh? When did that happen, last week? Congratulations! :lol:
Tue May 15, 2018 4:33 pm
durosity offline
Yes the operation was a complete success!
Tue May 15, 2018 4:38 pm
ckeyes888 offline
“Can you still return the item?”
Actually did finally get most all of my weather station stuff working with it.
The response time is much faster for temps, wind speed etc. so it’s not all bad.
Seems really odd that it won’t do X10 stuff, especially since it’s sold as being compatible.
Carl
