Not getting location information
Sat Mar 17, 2018 10:21 am
roussell offline
First off, thanks for the great plugin!!
I bought a couple of the Automatic Pro devices a few weeks ago for my and my wife's car, and loaded up your plugin. I requested, and was approved for "scope:current_location" and have checked the appropriate box in the plugin config. I have also entered the API key information for google's location API (I think I have anyway, there was a different API key for geolocation, and for distance matrix - I've tried both). I've also entered my home address in the config page, but I get nothing for the ETA, currentMilesFromHome, location, or previousMilesFromHome.
I don't see any errors in the Event log, but in the Custom States window, I do see the following error:
tag = {"detail": "Page not found", "error": "err_page_not_found"}
Any advice on how to get the location info working?
Terry
Sat Mar 17, 2018 5:05 pm
mlooss offline
Re: Not getting location information
So I too finally received my developer access approval and I thought I had everything configured and working. The car shows 0 miles from home in Indigo but now I am getting these errors:
Automatic OBD-II FYI - Exception caught getting vehicle info: state value type must be bool, int, real, or string
Automatic OBD-II 2005 Ford Explorer Sport Trac XLS:ignition:on @ 2018-03-17 18:58:09
Automatic OBD-II Location unknown, distance matrix calculation failed: 'ascii' codec can't encode character u'\xf1' in position 19: ordinal not in range(128)
Automatic OBD-II Location unknown, geocode failed: list index out of range
Automatic OBD-II 2005 Ford Explorer Sport Trac XLS En Route; At unknown location, unknown ETA
Trigger Update server memory variable
Thanks in advance for any suggestion to solve this.
Sun Apr 01, 2018 6:15 am
maslett offline
Me too. Mark
Wed Apr 11, 2018 8:04 am
dgarozzo offline
I don't know how I missed these posts. Are you guys up and running now? Any problems?
Sun May 06, 2018 6:00 am
roussell offline
I’m not working correctly, however with Google moving to Paid access it might be moot. Any plans to move to a different service?
Terry
Thu Apr 04, 2019 4:15 pm
dgarozzo offline
I'm not aware of Google moving to a paid service. My plugin continues to work fine for me. Maybe I'm grandfathered in?
Do you have the latest version of the plugin (1.0.6)? Can you enable debug logs and send me them?
Thu Apr 04, 2019 4:39 pm
Yeah, Google isn't doing map lookups for free any more. I haven't said anything since a post a while back, but I sure would LOVE to see a different (free) geofence option in this plugin. I literally bought 2 of these specifically to use this plugin only to have Google cut me off at the knees 2 days after I received them... :cry:
Sat Apr 06, 2019 4:27 pm
dgarozzo offline
Any suggestions on an alternative? I'd be happy to work on it.
Sat Apr 06, 2019 4:49 pm
dgarozzo offline
I just looked at developer.google.com, and I think you may have misunderstood their billing model? It looks like you get a $200 credit every month. It would be just you using your API call, so the chances of you exceeding $200 in charges would be slim to none. Plus, I believe I read that you can put a cap on the bill, so I would think you could set it up so the max monthly bill could be $200, which would result in no charges for the month after the $200 monthly credit.
Sat Apr 06, 2019 5:54 pm
My problem is mainly that it requires me to give Google a credit card. I don't trust Google with my credit card information. If they had a totally free account which didn't require me to add a credit card (would just stop working if I went over) then I'd be slightly more inclined (but only slightly).
I don't know of an alternative off the top of my head, but I'm betting there is one out there somewhere.
Sat Apr 06, 2019 6:39 pm
durosity offline
Could you use a pre-paid debit card with a very low balance on it?
