Dummy device temperature
Mon Apr 30, 2018 7:02 am
qcvictor offline
Hi Guys
I would like created dummy temperature device where he will be filled by third party via plugin GhostXML, I read couple weeks ago about plugin who can handle/create this kind of sensor but I'm unable to put my finger on it.
Vic
Mon Apr 30, 2018 10:12 am
Re: Dummy device temperature
I thought GhostXML created the devices?
Mon Apr 30, 2018 10:43 am
It does use discrete devices, but it saves all states as strings. This is for simplicity on the plugin’s behalf—the data would have to be converted somehow for numeric comparisons.
Mon Apr 30, 2018 12:43 pm
In that case, perhaps the Device Extensions plugin would work (I don't know for sure but it seems like it may).
Mon Apr 30, 2018 2:47 pm
qcvictor offline
So I give it a try to device extension where "the conversion extension" look promising cause the value to display are in Fahrenheit and want get in Celsius unfortunately doesn't work, I will post and ask in the right forum.
Dummy device where we will be able to push and select different units (Litre, gallon miles, kwh.........etc ) will be great add on...
Tue May 01, 2018 12:50 pm
qcvictor offline
Does Indigo-Masquerade from FlyingDiver will do ?
http://forums.indigodomo.com/viewtopic.php?f=216&t=17402
Tue May 01, 2018 1:13 pm
I'm not sure. Exactly what are you trying to do? The previous comments in the thread are very vague.
Tue May 01, 2018 1:50 pm
qcvictor offline
I would like get an temperature device where the temperature value will be filled by third party (Autelis pool controller in my case) via xml file parsed with GhostXML plugin,
Tue May 01, 2018 1:59 pm
Have you tried using the Pentair Pool plugin? It works with the Autelis controller.
In any case, the Masquerade plugin will not do what you want. It currently only does on/off type sensors (motion, power indicators, etc). Plus dimmers and speedcontrol (fans). But not value sensors, which a temp sensor would be.
Tue May 01, 2018 5:17 pm
qcvictor offline
Yes I tried the Pentair Pool plugin and also the autelis jandy, unfortunately dowsn't work, my Panel is Hayward/Goldline....
Tue May 01, 2018 6:15 pm
I believe this will work.
The Adapters Plugin can convert the string value to a float.
Create a new Adapters device that points to the device (the GhostXML device) state you want.
Create an Adapters device of type Custom Formula Adapter (numeric result).
Under the formula, use x * 1 (to be honest, you can probably just use x).
The resulting Adapters device state will be a float, that you can then key on.
Wed May 02, 2018 8:57 am
qcvictor offline
Thanks you so much DaveL17 to point me the right plugin, he work perfectly with xml parsed, so next step is to get another temperature sensor via MQTT. Did you have tried ?
Wed May 02, 2018 9:35 am
I’m not familiar with MQTT, but if your data source publishes XML or JSON, the GhostXML plugin should be able to work with it.
