how to run a script ONLY ONCE at start of indigo
Wed Apr 25, 2018 11:17 am
Has someone figured out how to run eg a script (or action ...) only ONCE at startup?
setting a variable to "started" does not work as you need to reset it when indigo shuts down .. and there is no mechanism for that either ..
anyway looking for suggestions.
Wed Apr 25, 2018 11:28 am
Colorado4Wheeler offline
Re: how to run a script ONLY ONCE at start of indigo
Why not write a file to the filesystem?
Wed Apr 25, 2018 11:38 am
Wed Apr 25, 2018 2:20 pm
jay (support) wrote:
Wow, I didn't even know that was a thing. I love learning new tricks.
Wed Apr 25, 2018 3:01 pm
LOL - been in there since Indigo 2 I believe.
Wed Apr 25, 2018 3:25 pm
While I would like to know every last possible thing that I can code into Indigo, I'm not you :shock: :lol:. Besides, that's a pretty obscure little technique that I bet hasn't been used by many and glazed over by most when reading the docs :roll: :wink: .
Wed Apr 25, 2018 3:41 pm
Actually, it's probably the best way to start up stay-open scripts (things that query data sources, populate variables, etc.) that should pretty much always be running while the server is running. We recommended it for background scripts like the old iTunes Sync script for example.
Wed Apr 25, 2018 4:43 pm
thats great !!
Now how about when indigo shuts down ..
how about a basic plugin that runs, does nothing, Only when indigo shuts it down it does an action when
  while True:
       time.sleep(10)
except: pass
###do the action here
would that work?
Wed Apr 25, 2018 5:10 pm
Or implement the shutdown() method:
def shutdown(self):
It would just have to do whatever it wanted to do quickly since I think we only wait for a plugin to shut down gracefully for 10 seconds.
Wed Apr 25, 2018 5:14 pm
Can shutdown() still call/ execute an indigo action ?
Wed Apr 25, 2018 10:09 pm
Yes it can and it works fine.
Have written a plugin if anyone is interested
Thu Apr 26, 2018 5:42 am
I never thought about using shutdown() with a server shutdown, but that makes sense. Do running plugins always shut down in alphabetical order? If that's the case, would "zzzPlugin" be "guaranteed" last to go?
Thu Apr 26, 2018 8:50 am
First, remember that shutdown() will also be called if the plugin is disabled or restarted - so you're not guaranteed that the server is also shutting down.
There is no explicit order of plugin shutdowns (that is, there is an order, but we don't publish it because it probably will change periodically as we do more backend server work so you shouldn't assume there is).
Thu Apr 26, 2018 8:54 am
Thanks Jay. Then the trigger seems like the best bet to key on a server shutdown.
Thu Apr 26, 2018 9:04 am
Unfortunately, at the moment there isn't a Server Shutdown trigger that corresponds to the Server Startup trigger. It's been on the list for many years, but just doesn't seem to have a very high demand.
