Import Subprocess osascript versus Import Applescript
Thu Apr 19, 2018 12:03 pm
Monstergerm offline
What are the pros and cons of running applescripts in the python environment using either the older subprocess osascript method versus importing applescript?
Thu Apr 19, 2018 1:04 pm
Colorado4Wheeler offline
Re: Import Subprocess osascript versus Import Applescrip
The subprocess is going to be harder to execute long scripts, but easy to execute an actual script file. The AppleScript library can do better at 'ad lib' scripting. My plugin uses the AppleScript library to run script files directly.
Mostly it's whatever your preference is and what the need is.
Tue Apr 24, 2018 9:18 am
Using subprocess will, as the name applies, create a new process for the script to run in which is inherently a more expensive operation than just importing py-applescript.
