Dict efficiency
Tue Apr 17, 2018 4:03 am
Dict efficiency
I’ve got a dict of about 30 keys, which I push straight into matching dev states.
However about 8 of the keys don’t make sense to the end user so I want to intercept and change them on the fly.
Which is best / what’s the best way:
(I’m typing on phone from memory so syntax is intentionally sloppy)
#Check k several times each loop
for k,v in myDict:
  if k == “abc”, k=“newabc”
  if k == “def”, k = “newdef”
...etc
dev.states[k]=v
#Check k once per loop, then only check again if it’s in list of swaps
for k,v in myDict:
  if k in kSwapsList:
...etc
dev.states[k]=v
#Brute force without checking
for k,v in myDict:
  k = replace(“abc”,”newabc”)
...etc
dev.states[k]=v
I presume option 2 is better than 1, but where does 3 fit?
Tue Apr 17, 2018 5:43 am
Re: Dict efficiency
If I know that I'm only going to do the change once per cycle, I prefer something like:
for k in myDict.keys():
    if myDict[k] == "abc": myDict[k] = "newabc"
    if myDict[k] == "def": myDict[k] = "newdef"
But if efficiency is your ultimate goal, you can always test various constructions using timeit:
https://docs.python.org/2/library/timeit.html
Tue Apr 17, 2018 6:02 am
Re: Dict efficiency
It’s the key names, not values, I’m testing/updating.
Tesla API gives you loads of state/value pairs, but door states are “fl”, “fr”, “rl” and “rr” off top of my head.
I want to intercept and name them “door_fl” etc, every time the car status is refreshed.
Peter
Tue Apr 17, 2018 6:09 am
Re: Dict efficiency
Sorry, missed that bit. I think this will work for unordered dicts:
    if k == "abc": myDict["newabc"] = myDict.pop(k)
Tue Apr 17, 2018 6:14 am
Re: Dict efficiency
I probably wouldn't loop at all.
myDict["new_abc"] = myDict["abc"]
del myDict["abc"]
myDict["new_def"] = myDict["def"]
del myDict["def"]
for k,v in myDict:
    dev.states[k]=v
Or maybe:
for k,v in myDict:
    if k == “abc”: dev.states["new_abc"]=v
    elif k == “def":  dev.states["new_def"]=v
    else: dev.states[k]=v
Tue Apr 17, 2018 10:23 am
kmarkley offline
Re: Dict efficiency
I suspect it is not very efficient, but for simplicity I like to use a translation dictionary:
kStateNames = {
   'abc': 'newabc',
   'def': 'newdef',
for k,v in myDict.items():
   dev.states[kStateNames.get(k,k)] = v
