Nanoleaf Rhythm?
Sat Sep 16, 2017 7:37 am
Nanoleaf Rhythm?
I just got in on the Rhythm preview sale, and now I'm wondering if the Rhythm scenes are exposed to Indigo the same way normal scenes are.
If Autolog doesn't have a Rhythm, I'm happy to provide whatever output necessary from logs. Once it arrives.
Oh, and watch your junk mail, because this "hey we have a few extra units" email came to me this morning. They won't last long.
Sat Sep 16, 2017 7:48 am
autolog offline
Re: Nanoleaf Rhythm?
Once you get your Rhythm you will find out and can share the info with us. :)
If Autolog doesn't have a Rhythm, I'm happy to provide whatever output necessary from logs. Once it arrives..
I have just asked him and apparently he doesn't have a Rhythm and hasn't ordered one. :wink:
Wed Sep 20, 2017 5:17 pm
I got Rhythm!
Plug it in, Nanoleaf app demands an update, which the app says will take 15 minutes, but was more like 1.5 minutes.
After that, the Rhythm works perfectly with Indigo, as the Rhythm scenes are treated just like regular scenes and the plugin detected them immediately.
Great work AutoLog!
Fri Apr 13, 2018 9:07 am
Busta999 offline
Just got a Rhythm and a bunch of Nanoleaf panels.
Hard wired the Nanoleaf into Lounge Sound system.
Put some triggers in to detect when certain songs are played on the Lounge AppleTV Plex.
When a particular song plays, dims all the Hue lamps in the room and sets them to a colour scheme that complements the Nanaoleaf Rhythm , and sets Nanoleaf to the Rhythm scheme that best suits the song.
I have created a playlist in Plex that work great with a Nanoleaf light show.
Mesmerising :-)
Thanks to @autolog @NathanSheldon @RoagueProeliator plus the guys at Indigo :-)
Fri Apr 13, 2018 9:16 am
Video please!
Fri Apr 13, 2018 10:05 am
I do something quite similar. I have a series of triggers that look at what the effect on the Nanoleaf is currently, and changes it to the next one in the list each time a song starts.
Fri Apr 13, 2018 10:29 am
Busta999 offline
Abou to video it and the Nanoleaf plug has exploded :-(
   Enabling plugin "Nanoleaf 1.1.0"
   Starting plugin "Nanoleaf 1.1.0" (pid 22095)
   Nanoleaf                        Autolog 'Nanoleaf V1 Controller' initializing . . .
   Nanoleaf                        Host IP Address overridden and specified as: '192.168.1.10'
   Nanoleaf                        No monitoring or debugging requested
   Started plugin "Nanoleaf 1.1.0"
   Nanoleaf                        Initialising to poll at 300 second intervals
   Nanoleaf                        Autolog 'Nanoleaf V1 Controller' initialization complete
   Nanoleaf                        Starting  'Light Art' . . .
   Nanoleaf                        Discovering nanoleaf devices on network - this should take ~30.0 seconds . . .
   Nanoleaf                        . . . Started 'Light Art'
   Nanoleaf Error                  Discovering nanoleaf devices failed: Socket error while setting up host '192.168.1.10' discovery of nanoleaf devices!: [Errno 49] Can't assign requested address
   Nanoleaf                        Autolog 'Nanoleaf V1 Controller' checking for Plugin update
   Nanoleaf                        Checking for updates...
   Nanoleaf Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 439, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
   Nanoleaf Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Plus I am getting these vomiting in the log
13 Apr 2018, 17:24:25
   Error                           cannot update device state for key clientConnectionStatus to value buffering (invalid enumeration value)
   Z-Wave                          received "Heating System Power Monitor" energy total to 0.9220 kWh
   Z-Wave                          received "Heating System Power Monitor" power load to 4.3 W
   Trigger                         Heating is Off
   Trigger                         Heating is No Longer Cooling Down
Nanoleaf is responding to iOS App instructions and Alexa instructions.
Nanoleaf rebooted.
Fri Apr 13, 2018 10:43 am
autolog offline
Uncheck Check for Updates in the plugin config, save and then reload the plugin. :)
Fri Apr 13, 2018 10:55 am
Busta999 offline
Thanks Jon,
Nanoleaf back online.
@Different Computers has the right idea, I’ll look to how to implement that but still good for the Nanoleaf Demo to have songs linked explicitly.... :-)
Will do a video tonight so it is Dark
Not sure how I’ll full room in...
Fri Apr 13, 2018 11:35 am
I would love to figure out how to select a Rhythm scene based on the iTunes song's genre, rather than just a change of song.
So I can have blue scenes for the blues, for example.
Fri Apr 13, 2018 11:52 am
Busta999 offline
I am using Plex as my main music player in the house and on mobile.
I put my entire music library on a spare 1TB OneDrive I wasn’t using, run Plex Cloud on that means my songs are available 7x24 anywhere.
Can also cache songs locally and play the songs from echoes around the house.
Is there no way to get the genre from the Plex song playing ?
That would be nice., then I could link genre to Nanoleaf
Fri Apr 13, 2018 1:01 pm
Dunno about genre in Plex, as I don't use it as a music player. I don't see genre available in the iTunes plugin.
Fri Apr 13, 2018 1:11 pm
Busta999 offline
@Jay. Video as requested
https://youtu.be/3DwaEN380Pc
Camera work not good but shows what is happening.
Mike
Sat Apr 14, 2018 8:47 am
Excellent!
