Sat Jan 27, 2018 10:37 am
this should only occur if the PI positions are not set in RPI device edit . == quick fix set the xyz positions of your RPIs
will add an IF in the position calculations
Thu Apr 12, 2018 5:22 pm
posted new version on GitHub also a new SSD image https://www.indigodomo.com/pluginstore/59/ for RPI3+
Sat Apr 21, 2018 10:10 am
posted new version on GitHub https://www.indigodomo.com/pluginstore/59/ for RPI3+
- added particulate (air quality) sensor PMS5003 (from adafruit$40 or at ebay $20 w 3 weeks delivery)
-all sensors are now separate python programs on RPI (makes it easier to maintain
-fixed smaller typos ...
This sensor PMS5003 allows to measure the particulate contents of air. In the plugin it will show red/grey/red for air quality and here all the numbers :
Screen Shot 2018-04-21 at 09.57.39.png (18.01 KiB) Viewed 2973 times
Screen Shot 2018-04-21 at 09.57.56.png (42.56 KiB) Viewed 2973 times
You need to connect 3 wires:
1. +5V to Vcc
2. Ground to Ground
3. RX to TX on sensor
Together with the BME680 and the CO2/ VCC and various light sensors you now have a full spectrum of sensors you can measure almost anything at home:
-Temperature
-Humidity
-Pressure
-Air quality (VOCs)
-CO2
-Light: ultraviolet, 5 different visible wavelengths, infrared
-particulates
Sat Apr 21, 2018 9:20 pm
using the particulate sensor to measure the efficiency for a HEPA filter.
This actually works (filter and sensor)!! shown is the 0.3um/m**3 count
Screen Shot 2018-04-21 at 23.02.32.png (82.7 KiB) Viewed 2940 times
Shortly before 20:00 (8pm) a HEPA air purify was switched on
Mon Jun 11, 2018 1:01 am
GlennNZ offline
Hi Karl,
Getting this with the just posted version 7.86.220
   piBeacon                        setup pi response (1) message
   piBeacon                        setup pi response (1) error
couldn't read file "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateAllFiles.exp": no such file or directory
Manually re-created it with Plugin Contents and all-good.
Seems you missed one reference to it on line 7930?
G
Mon Jun 11, 2018 6:50 am
That’s a real bug. I renamed the file.
Mon Jun 11, 2018 7:29 am
posted the fix on plugin store and GitHub for error: "...updateAllFiles.exp": no such file or..."
v .221
Sat Aug 25, 2018 9:15 pm
GlennNZ offline
Hi Karl,
Just a quick question regarding sensors and pi beacon. Multiple Rpis and sensors all going well and quite stable.
Couple of non-urgent questions; as seem to recall from recent posts that you are traveling...
1.
Have a couple of sensors that want to add twice (different calculation for display image purposes for example).
Is this supported? Seem to have minor issues when I try.
Eg.
One Rpi
Ads1115 Sensor, one channel
Can I add/create two indigo pibeacon devices that access this one sensor? (Then have different display calculations/status etc)
If not can overcome by creating variables, using other plugins.. etc - but you give so many good calculation and adjustment options that adding two sensors would be easier/ideal.
2. The Ads1115 sensor device seems to be missing the sensor changed/max/min, last sensor update - addition states that other sensors were updated with previously?
Thanks again.
Glenn
Sat Aug 25, 2018 10:11 pm
in principle you should be able to add a sensor twice, as each sensor has its own dict section. , but I have not tried that . .. just try it.
as for min max, I can add that when I am back, just adding the min max/ yesterday .. states to device.xml I believe and may be add the device type to a list
Karl≠≠
Sat Aug 25, 2018 11:39 pm
GlennNZ offline
Karl≠≠
Thanks for quick reply and as said no rush as all working well.
Two sensors the same pi/same device - seems to give fix sensor error and then never updates. Presume something code wise stopping this.
Edit: although I do have two duplicated GPIO_inputs sensors which work fine.
Glenn
Sun Aug 26, 2018 2:22 am
could you post the exact error msg "seems to give fix sensor error"..
Sun Aug 26, 2018 2:31 am
GlennNZ offline
2018-08-26 12:41:47.217   piBeacon   fixing 2  piBeacon Level Sensor 185 rpi copy  680385196 pi 5 sensori2cADS1x15
Thanks.
(sorry just normal logging - but should be easy to reproduce - and as said no biggie )
Sun Aug 26, 2018 3:46 am
to fix that I need to be home..
I believe I have the min./Max and last update ready, was easy..
will post a prel version on dropbox later.
Sun Aug 26, 2018 7:20 am
test version w min/Max, lastchanged sensor for ADC 1115
https://www.dropbox.com/s/a7s6bc3rd6lc7id/piBeacon.indigoPlugin.zip?dl=1
Mon Aug 27, 2018 1:52 am
GlennNZ offline
Thanks Karl
Is the download link correct? - links to version 7.85.220 version last modified 3rd June?
Glenn
Page 64 of 78 1 ... 61, 62, 63, 64, 65, 66, 67 ... 78
Users browsing this forum: No registered users and 17 guests
