Error RFXcom 2.18
Fri Mar 30, 2018 5:17 am
marcel langelaan offline
Error RFXcom 2.18
Please advice, i get the following errors:
30 Mar 2018 at 13:14:28
RFXCOM Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 309, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 2233, in startComm
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 749, in processPacket
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 1333, in handleRFXSensor
UnboundLocalError: local variable 'temp' referenced before assignment
RFXCOM Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Fri Mar 30, 2018 5:21 am
Re: Error RFXcom 2.18
Downgraded and re-installed => working
Sorry
Fri Mar 30, 2018 5:49 am
Error RFXcom 2.18
fixed typo "temperture" ==> temp as variable name should work now, but not tested
https://www.dropbox.com/s/3kev5jvqh18qeav/RFXCOM-v-2.1.9.zip?dl=1
as I am not the authorI can't push to the plugin store.
Fri Mar 30, 2018 9:46 am
Did you issue a pull request in Github with the fix?
Fri Mar 30, 2018 9:58 am
Issue occurs again, after certain time.
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/RFXCOM-218indigoPlugin.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 2233, in startComm
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/RFXCOM-218indigoPlugin.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 749, in processPacket
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/RFXCOM-218indigoPlugin.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 1333, in handleRFXSensor
I will try the 2.19 version later.
Fri Mar 30, 2018 10:15 am
Jay
just downloaded the latest and changed the code. Changed v # and posted on my Dropbox.
Fri Mar 30, 2018 10:27 am
If you follow the standard process (fork, fix, issue pull request) on Github then fixing bugs like this would result in a new release. We don't want lots of different versions (potentially with the same version #) floating around. And this is exactly why we use Github in the first place.
Fri Mar 30, 2018 10:28 am
sorry need to get used to GitHub
Fri Mar 30, 2018 4:02 pm
I've written up a guide to contributing to existing open source plugins on GitHub that may be of some help.
Sun Apr 01, 2018 3:30 am
2.19 seems to work, thx
Mon Apr 09, 2018 10:52 am
I've added this fix into a new release (2.1.10).
