5 May 2018 at 15:17:53
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 20 03 25 01 FF 25 E4 DF
Z-Wave sent "032 - MCO 1" on
howartp wrote:Can you go to interfaces > Zwave > associations and see what’s listed for this device.
I suspect you need to add an association for group 5, node 1.
This tells the module to send status reports to node 1 (the controller).
Group Max Nodes Description
1 1 Lifeline
2 5 Associate with Key 1 - send Basic Set Command to associated devices
5 5 Associate with Key 2 - send Basic Set Command to associated devices
8 5 Associate with Key 3 - send Basic Set Command to associated devices
11 5 Associate with Key 4 - send Basic Set Command to associated devices
The switch supports 5 association groups.
The first four groups are used for switching associated devices(switch N controlling group N),and each group can support up to 5 nodes or terminals.
The 5th association group is used for reporting devices’ state to the controller if any changes happen. This group supports one node, which defaults to controller node.
The device supports several (key numbers +1) association groups (AG). The 1st AG is used for
reporting devices’state to the controller if any changes happen. This group supports one Node, which
suggested to be controller Node. The rest AGs are used for switching associated devices,and they
can support up to 5 nodes each.
Scotfree wrote:I have a couple of these MCO switches - 4 button Gen5s working as scene controllers, without anything physically attached to the relays but using virtual devices to activate/monitor scenes. They work well and look great but one annoying aspect is that whenever there is a restart of the ZWave controller or Indigo server (or sometimes when it feels like) the device goes into a state where the buttons will become out of sync. By that, I mean if you press switch 1, switch 3 comes on in the Indigo switch device and so on.
I've tried sending status requests and setting to 'Poll only when activity detected' but nothing seems to resolve this state until I do a re-sync of the device. Any suggestions on how to handle this ?
