Convert to Python?
Mon Apr 02, 2018 2:34 pm
ckeyes888 offline
Convert to Python?
Is something like this AS convertible to Python?
set someString to value of variable "CID_Display_Name"
set noTrailingSpacesString to removeTrailingSpaces(someString)
on removeTrailingSpaces(theString)
   repeat while theString ends with space
      set theString to text 1 thru -2 of theString
   end repeat
   --return theString
   set the value of variable "CID_Display_Name" to theString
end removeTrailingSpaces
Appreciate any help.
Carl
Mon Apr 02, 2018 2:44 pm
Re: Convert to Python?
no_trailing_spaces_string = indigo.variables[VARIDHERE].value.rstrip()
no_leading_spaces_string = indigo.variables[VARIDHERE].value.lstrip()
no_leading_or_trailing_spaces_string = indigo.variables[VARIDHERE].value.strip()
no_spaces_at_all_string = indigo.variables[VARIDHERE].value.replace(" ", "")
Python is so much better at string manipulation than AppleScript is. And with collections (lists, dictionaries, etc.). And with... ;)
Mon Apr 02, 2018 3:01 pm
ckeyes888 offline
Wow Jay, that’s impresssive.
Many thanks!
I have a number of this type of script that based on what you’ve done here I think I can convert.
Carl
Mon Apr 02, 2018 3:06 pm
ckeyes888 offline
Can I get greedy and do one more?
This is another I use a lot of.
   set the value of variable "GrowlAlert" to value of variable "CID_Display_Name" & " called at " & (value of variable "ClockTimeAmPm") & " " & (value of variable "CID_Display_Number") & " on " & (value of variable "DayShort") & " " & (value of variable "MonthShort") & " " & (value of variable "DateExt")
end tell
Many thanks,
Carl
Mon Apr 02, 2018 3:53 pm
new_string = "{} called at {} {} on {} {} {}".format(
    indigo.variables["CID_Display_Name"].value,
    indigo.variables["ClockTimeAmPm"].value,
    indigo.variables["CID_Display_Number"].value,
    indigo.variables["DayShort"].value,
    indigo.variables["MonthShort"].value,
    indigo.variables["DateExt"].value
indigo.variable.updateValue( "GrowlAlert", new_string)
But you're better off using the ID of the variable than the name.
Mon Apr 02, 2018 4:05 pm
+1 - you should always use IDs (which don't change) rather than names (that do change).
Mon Apr 02, 2018 4:06 pm
I was being lazy. :)
Mon Apr 02, 2018 4:08 pm
I edited your script so it's a bit easier to read (and because that little info box overlaps code blocks - still haven't figured out how to fix that in the CSS).
Mon Apr 02, 2018 4:10 pm
By the way, another thing that Python is SIGNIFICANTLY better at is dates and times - calculating, formatting, etc., is all a lot more flexible in Python. Not sure how those variables are getting populated, but you may be able to save yourself some time and variables if they're only there as a holding place for their calculation.
Mon Apr 02, 2018 4:14 pm
I've also taken to doing it like this to improve clarity a little:
f_string = "{} called at {} {} on {} {} {}"
new_string = f_string.format(
Mon Apr 02, 2018 4:48 pm
ckeyes888 offline
Thanks, really appreciate all the help!
I should be able to convert a good chunk of my AS’s.
Carl
Mon Apr 02, 2018 7:22 pm
The author block doesn't overlap the code box in Safari (v11.1 anyway). It does shorten it, but it doesn't obscure it.
Mon Apr 02, 2018 7:23 pm
Although now that I think about it, the fact that I have visible scroll bars may have something to do with that.
Screen Shot 2018-04-02 at 8.22.33 PM.png (20.88 KiB) Viewed 2450 times
Tue Apr 03, 2018 9:16 am
Yeah, what I'd prefer is to have the code block start wrapping rather than scrolling under block. I'm not a CSS expert (and I think I'd probably go insane if I had to become one).
Tue Apr 03, 2018 9:35 am
Colorado4Wheeler offline
But if you wrapped the line then it wouldn't read like the original code. I actually like the scrolling because I see the code verbatim.
