Mar 31, 2018 at 9:30:57 AM
Pentair Pool Debug circuitcode is: POOLHT
Pentair Pool Debug Processing temp node from Autelis Status.xml...
Pentair Pool Error Error in plugin execution ExecuteAction:
File "plugin.py", line 381, in actionControlThermostat
File "plugin.py", line 534, in autelisProcessTemp
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 1300, in XML
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 1642, in feed
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 1506, in _raiseerror
ParseError: syntax error: line 1, column 0
Pentair Pool Debug From Pentair: !00 OPMODE = SERVICE/TIMEOUT
Pentair Pool Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 237, in runConcurrentThread
File "plugin.py", line 309, in parseToServer
ValueError: invalid literal for int() with base 10: 'SERVICE/TIMEOUT'
Pentair Pool Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
farberm wrote:I am using your new plug-in with link adapter. When I set up Pool for intellitouch circuit it reads that the pump is off when it is on. Not sure why. It reads the Pool and spa temperature correctly and the spa pump reads on correctly?
ticotice wrote:Just installed the Pentair Plugin v2. However, I'm unable to get your plugin to display any information in Indigo. Here's my setup:
- Pentair EasyTouch panel with an Autelis Controller connected via WiFi through an EnGenius ENS202 outdoor bridge.
I'm guessing the plugin may not work with the EasyTouch panel. Is that correct?
tornado wrote:I'm wondering if this plugin needs its own section?
Anyway I was trying to use it with my Autelis controller today. I got this error back when creating a temperature controller:
- Code: Select all
Any suggestions?
FlyingDiver wrote:Plugin doesn't handle service mode. See response from the Intellitouch:
- Code: Select all
Swancoat wrote:My main recommendation is to just not use the service mode. In the event you simply must, I have posted v2.0.1 with a fix for this. As with farberm's issue, I do not have a working iLink adapter, so I haven't been able to test the fix. Please let me know if this does the trick or not.
FlyingDiver wrote:Swancoat wrote:My main recommendation is to just not use the service mode. In the event you simply must, I have posted v2.0.1 with a fix for this. As with farberm's issue, I do not have a working iLink adapter, so I haven't been able to test the fix. Please let me know if this does the trick or not.
Wasn't really my choice. Had to put the panel in service mode to deal with a pump not working properly.
Users browsing this forum: No registered users and 38 guests
