Have some trouble with json import, device stay stuck on "Processing" and no refresh anymore,
{"System":{
"Build":20102,
"Git Build":"mega-20180429",
"Local time":"2018-05-03 08:05:53",
"Unit":7,
"Name":"Wemos Pool Controller",
"Uptime":4671,
"Load":26,
"Load LC":11282,
"Free RAM":17912
"WiFi":{
"Hostname":"Wemos-Pool-Controller-7",
"IP config":"DHCP",
"IP":"10.0.0.XX",
"Subnet Mask":"255.255.255.0",
"Gateway IP":"10.0.X.X",
"MAC address":"5C:CF:7F:F0:28:8A",
"DNS 1":"10.0.X.X",
"DNS 2":"X.X.X.X",
"SSID":"XXXXXXXX",
"BSSID":"F0:9F:C2:A4:AE:EF",
"Channel":1,
"Connected msec":136965665,
"Last Disconnect Reason":201,
"Last Disconnect Reason str":"(201) No AP found",
"Number reconnects":26,
"RSSI":-53
"Sensors":[
"TaskNumber":1,
"Type":"Analog input - ADS1115",
"TaskName":"pH",
"TaskValues": [
{"ValueNumber":1,
"Name":"pH",
"Value":11.50}]
"TaskNumber":2,
"Type":"Analog input - internal",
"TaskName":"Pressure Filter",
"TaskValues": [
{"ValueNumber":1,
"Name":"Bar",
"Value":0.91}]
"TaskNumber":3,
"Type":"Display - LCD2004",
"TaskName":"Screen"},
"TaskNumber":4,
"TaskName":"Orp",
"TaskValues": [
{"ValueNumber":1,
"Name":"Orp",
"Value":171.51}]
"TaskNumber":5,
"Type":"Switch input - Switch",
"TaskName":"PIR",
"TaskValues": [
{"ValueNumber":1,
"Name":"Switch",
"Value":0}]
"TaskNumber":6,
"Type":"Environment - DS18b20",
"TaskName":"Temperature",
"TaskValues": [
{"ValueNumber":1,
"Name":"Temperature",
"Value":9.06}]
"TaskNumber":7,
"Type":"Generic - Pulse counter",
"TaskName":"Water Flow",
"TaskValues": [
{"ValueNumber":1,
"Name":"Count",
"Value":0.00},
{"ValueNumber":2,
"Name":"Total",
"Value":0.00},
{"ValueNumber":3,
"Name":"Time",
"Value":0.00}]
"TaskNumber":9,
"Type":"Generic - Dummy Device",
"TaskName":"Test",
"TaskValues": [
{"ValueNumber":1,
"Name":"[Pressure Filter#Bar]+10",
"Value":0.00},
{"ValueNumber":2,
"Name":"Pressure Filter#Bar +10",
"Value":0.00},
{"ValueNumber":3,
"Name":"",
"Value":0.00},
{"ValueNumber":4,
"Name":"",
"Value":0.00}]
