Device Filtering from Actions.xml
Fri Mar 09, 2018 1:37 pm
I think I understand the updates to device filtering in the current API, and I think this case isn't covered but wanted to make sure. Within Actions.xml, I filter on "self" which returns all the device types defined within the plugin. However, I have one device type for which a particular action is not appropriate. There isn't a way to filter out device types, so if I want to keep that device type from being returned, I need to AND together all the devices except that one type. To exclude deviceType3:
  <Action id="action_id" deviceFilter="self.deviceType1, self.deviceType2, self.deviceType4" uiPath="DeviceActions">
    <Name>Action Name</Name>
    <CallbackMethod>actionCallbackMethod</CallbackMethod>
  </Action>
That works, I'm just double-checking to make sure that's the most efficient way.
Fri Mar 09, 2018 2:59 pm
Colorado4Wheeler offline
Re: Device Filtering from Actions.xml
Retracted.
Last edited by Colorado4Wheeler on Fri Mar 09, 2018 5:39 pm, edited 1 time in total.
Fri Mar 09, 2018 4:46 pm
Sure, that's fine, and would be slightly more efficient than a custom list since the server builds it rather than a separate round-trip to the plugin (which may call back into the server, etc).
Sat Mar 10, 2018 6:20 am
Hmmm. I don't know what I was looking at yesterday, but it seems I might've spoken too soon. When I list more than one device type id, I only get results for the last one in the list. It seems they may be OR'ing instead of AND'ing.
  <Action id="refreshAChartAction" deviceFilter="self.barChartingDevice" uiPath="DeviceActions">
    <Name>Redraw Chart</Name>
    <CallbackMethod>refreshAChartAction</CallbackMethod>
  </Action>
One device type id.
Screen Shot 2018-03-10 at 5.55.10 AM.png (35.36 KiB) Viewed 2206 times
  <Action id="refreshAChartAction" deviceFilter="self.barChartingDevice, self.lineChartingDevice" uiPath="DeviceActions">
  </Action>
Two device type ids.
Screen Shot 2018-03-10 at 5.56.51 AM.png (35.42 KiB) Viewed 2206 times
Seems I might have to provide a config UI for the action to deliver the custom list.
Sat Mar 10, 2018 10:48 am
Unfortunately, you are correct. While you can have more than one filter listed, it only accepts/uses one base/class filter. The additional filter arguments (which allow more than 1) apply to sub-types and properties. I think this might work:
<Action id="refreshAChartAction" deviceFilter="self, props.IsBar, props.IsLine" uiPath="DeviceActions"]
where you would have to set pluginProps for each of those appropriately either in the code, or via a hidden boolean in the Devices.XML:
newProps = someBarDev.pluginProps
newProps["IsBar"] = True
someBarDev.replacePluginPropsOnServer(newProps)
newProps = someLineDev.pluginProps
newProps["IsLine"] = True
someLineDev.replacePluginPropsOnServer(newProps)
Sat Mar 10, 2018 12:51 pm
Super Matt, thanks. What you're saying makes sense, is easy to implement and works perfectly.
I may make it a habit to add a similar prop element to the custom devices of all my plugins; I think it's worth it for this purpose alone.
Sat Mar 10, 2018 9:05 pm
Just as a follow-up, this is working great and is super fast. This is for the Matplotlib plugin and I chose to go with a binary test:
Actions.xml
<Action id="refreshAChartAction" deviceFilter="self, props.IsChart uiPath="DeviceActions">
plugin.py
newProps["IsChart"] = True
Thanks Matt!
Mon Mar 19, 2018 7:37 pm
Is there similar syntax for the Events.xml file? I need to create a trigger than only needs the device to be identified. I tried this, but didn't get a popup with devices with that property.
   <Event id="buttonPress"  deviceFilter="self, props.IsButton">
      <Name>Button Press</Name>
    </Event>
Tue Mar 20, 2018 6:29 pm
Bump. Anyone?
Tue Mar 20, 2018 6:45 pm
I think (but don't know for sure) that you'll have to set it up through a config ui. I've tried a couple different attempts -- with and without the specific filter and with and without a callback and no luck.
Tue Mar 20, 2018 6:58 pm
Not sure it's still true, but I did find this which indicates that deviceFilter is not implemented for events.
http://forums.indigodomo.com/viewtopic.php?f=108&t=10714&hilit=events+popup#p69570
Tue Mar 20, 2018 6:59 pm
Oh well, writing some short functions....
Wed Mar 21, 2018 8:49 am
Sorry for the slow response. Dave is correct – not currently implemented but is on the API request list.
Wed Mar 21, 2018 8:52 am
That's cool. I missed that old thread about it. Already done with that part of the code.
