Cynical SecuritySpy Error attempt to use missing devi
Wed Jun 14, 2017 4:39 pm
captcurrent offline
I started getting this error recently The device is it cites does not exist,, Any thought how I can track this vermin down
Thu Jun 22, 2017 7:42 am
captcurrent offline
Re: Cynical SecuritySpy Error attempt to use missing d
I have tried deleting all security spy devices and rebulding no luck still get same error
Fri Jun 23, 2017 11:27 am
Post some logs then we can see what you're on about.
Fri Jun 23, 2017 12:56 pm
captcurrent offline
un 23, 2017, 2:40:20 PM
Script not good
Updated "Security" on
Script phone script false
Cynical SecuritySpy Error attempt to use missing device id 180716725
Jun 23, 2017, 2:40:45 PM
Its not the phone scripts as the majprity of teh log entries for teh script aere clean
Script not good
Jun 23, 2017, 2:42:00 PM
Schedule PhoneConfirm-New
Jun 23, 2017, 2:42:20 PM
Script not good
Jun 23, 2017, 2:43:00 PM
Jun 23, 2017, 2:43:20 PM
Script not good
Jun 23, 2017, 2:44:00 PM
Jun 23, 2017, 2:44:20 PM
Script not good
Script
Sat Jun 24, 2017 8:13 am
captcurrent offline
after MUCH trial and eror and deleting and re-adding devices.. I traced it down to one camera
I tried deleting, renaminn changing IP all in vain
I reinstalled the plug in and I am now bacl to just my usual problems with indigo
thanks for sounding board
Wed Aug 02, 2017 8:40 am
captcurrent offline
So much for my solution.. my problem is back
Aug 2, 2017, 9:42:39 AM
   Cynical SecuritySpy Error       attempt to use missing device id 46504770
Thos is just one example Theeseems to be a relationship between whether Ihave armed the cameras or not.
There is no device with this id.
Ther is no trigger or action group being called
Does anyone know where SS plugin keeps its data base of devices??
Sat Mar 17, 2018 7:29 am
jalves offline
I'm experiencing the same issue. Wondering if there's been a resolution as I don't readily see it in other threads here. For the record I'm using version 2.3 of the plug-in. Similar issue, no camera with the reported device number (obviously!) and restarting the plugin doesn't seem to clear it.
Running Indigo 7.2.0 on a 27" iMac (mid-2017), 40G memory, 1T Fusion Drive, OS X 10.13.6
Jeff
Sat Mar 17, 2018 7:59 am
captcurrent offline
When this problem occures I haveto delete and re=add all the cameras
Sat Mar 17, 2018 8:20 am
jalves offline
Thanks. I'm considering a complete de-instal of the plug-in and then re-installing and adding back the cameras. But first I'm going to check all my triggers/schedules/action groups for anything that might reference that camera, security spy or the plug-in.
Jeff
Sat Mar 17, 2018 9:15 am
jalves offline
Found it! At least I think I did. I found a Trigger referencing a camera that I had deleted since the camera no longer existed. No error messages for the last 30 minutes.
Jeff
Sat Mar 17, 2018 9:17 am
captcurrent offline
you did better then i Great job!
