Automatic OBD-II Indigo Plugin (discontinued)
Fri Mar 02, 2018 10:55 am
dgarozzo offline
Re: Automatic OBD-II Indigo Plugin
That sounds like a great idea! You should be able to see the json responses in the device variables, right? Do you need me to expose them some other way?
Fri Mar 02, 2018 11:01 am
DVDDave offline
dgarozzo wrote:
I will double check my directions on the required Google API access. Very sorry about that!
Thanks for the great plugin! Glad we got this figured out. :D
Fri Mar 02, 2018 11:04 am
rapamatic offline
I think it would be a lot easier to setup indigo triggers if the fuel level (or whatever we are interested in, maybe battery voltage too) is directly exposed as a device state (just like location, ETA, or currentMilesFromHome)...
Mon Mar 05, 2018 6:51 pm
dgarozzo offline
I currently use the following script as an Server Action Execute Script for a trigger of Type Automatic OBD-II Event, Event: Approaching Home.
car = indigo.devices["Automatic OBD Audi"]
indigo.server.speak("The car is almost home at " + car.states["location"])
One way you can create a trigger based on your fuel would be to create a Trigger on Device State Changed for your device. Choose the State: vehicle, Has Any Change. Then in Condition, you could script something like:
import json
car = indigo.devices["Automatic OBD Honda"]
myVechicleJson = json.loads(car.states["vehicle"])
indigo.server.log(myVehicleJson["fuel_level_percent"])
# code to return true if fuel level is below 10%
Except, ugh, it looks like the Condition has to be Applescript and not Python??!?!?!?!! So, you'd have to do that in the Action instead of the Condition (or figure out the Applescript equivalent), and then code your action in Python. That kinda stinks.
I'll work on breaking out the useful Vehicle attributes into States.
Tue Mar 06, 2018 7:00 pm
dgarozzo offline
v1.0.5 - Plugin has been updated to include fuelLevelPercent, batteryVoltage, and activeDtcs as States for the Device.
Thu Mar 08, 2018 9:25 am
rapamatic offline
Sweet, this is perfect - thanks man!
By the way, I'm getting a fair amount of exception notices in my log - I assume this is just some intermittent bad data coming in from automatic, but any way to not show these messages?
Messages like this:
Mar 8, 2018, 8:17:21 AM    Automatic OBD-II                FYI - Exception caught getting vehicle info: state value type must be bool, int, real, or string
-Ray
Thu Mar 08, 2018 3:28 pm
dgarozzo offline
Shouldn’t be any exceptions. I’ll look into it.
Messages like this:
-Ray
Thu Mar 08, 2018 3:29 pm
rapamatic offline
I'll turn on debugging so you get more info
Thu Mar 08, 2018 4:26 pm
rapamatic offline
Here's a sample debug log:
Mar 8, 2018, 4:09:40 PM
   Automatic OBD-II Debug          Automatic - Minivan
   Automatic OBD-II Debug          _refreshStatesFromAPI for Automatic - Minivan (C_400027b0f9a87963)
   Automatic OBD-II Debug          Bearer 8e5c1e5f52565eb889fc982921a27e1d0b3114b3
   Automatic OBD-II Debug          vehicleJson updated
   Automatic OBD-II Debug          {"model":"Odyssey","fuel_level_percent":52.0,"display_name":null,"url":"https://api.automatic.com/vehicle/C_400027b0f9a87963/","created_at":"2017-04-30T15:03:25.617000Z","battery_voltage":13.391,"active_dtcs":[],"updated_at":"2018-03-08T22:09:40.535000Z","submodel":"Touring Elite","year":2014,"fuel_grade":"regular","id":"C_400027b0f9a87963","make":"Honda"}
   Automatic OBD-II Debug          _addVehicleToCars: C_400027b0f9a87963
   Automatic OBD-II Debug          getting fuel level percent
   Automatic OBD-II Debug          getting battery voltage
   Automatic OBD-II Debug          getting active dtcs (MILs)
   Automatic OBD-II Debug          tripJson updated
Looks like its an issue with null data from the check engine light?
Mon Mar 19, 2018 2:41 pm
dgarozzo offline
v1.0.7 released. Should fix the exception.
Mon Mar 19, 2018 2:43 pm
dgarozzo offline
The problem wasn't null data - it was getting back a JSON object instead of a string. I needed to convert the JSON back to a string before setting the state.
Thu Aug 30, 2018 3:07 pm
Vig offline
Automatic has now 2 versions Lite and Pro. I assume Lite version would suffice?
Thu Aug 30, 2018 4:19 pm
dgarozzo offline
I’m pretty sure you’re gonna want the Pro.
Fri Aug 31, 2018 4:05 am
How much power does it consume.
Ie when I do not run the engine for 2 weeks will it drain the battery ... will the car still start?
Fri Aug 31, 2018 5:47 am
dgarozzo offline
I’ve never had a problem with it.
