Leap Year / Feb 29 = Mar 1
Thu Mar 01, 2018 1:19 pm
CraigM offline
I woke up this morning to discover that Indigo doesn't seem to respect Feb 29 as a February date.
All of my February schedules are set from Feb 1 to Feb 29 and they all show 'next execution' as March 1
This is obviously a problem since all of the real March schedules are now also running and conflicting with all the Feb schedules.
My HVAC and Irrigation are in a power struggle as to which schedules to run or they run both.
Thu Mar 01, 2018 1:26 pm
Re: Leap Year / Feb 29 = Mar 1
Did not know we have a leap year this year.
Today is March 1. ??
Thu Mar 01, 2018 1:36 pm
roussell offline
Yeh, March 1st here as well. Do you by chance have the wrong year as your date, or are we misunderstanding your problem? I seem to remember Indigo handling my leap-year-day schedules without issue.
Thu Mar 01, 2018 2:11 pm
CraigM offline
Obvious confusion
If you set your Feb schedules to:
start FEB 1 every year
end FEB 29 every year
this should cover you for normal 28 day years and leap years with 29 days
Today is March 1 and all my FEB schedules ran AND my March schedules ran
Even the UI displays 'next execution' as March 1 for the FEB schedules
Since there wasn't a FEB 29, shouldn't Indigo have skipped over the date? Why is Indigo seeing a setting of FEB 29 as a March event?
Thu Mar 01, 2018 2:23 pm
You are looking for a trigger for last day in the month?
Thu Mar 01, 2018 3:03 pm
CraigM offline
Not sure why the misunderstanding?
Test for yourself:
Create a schedule that-
it will run today, today is NOT a FEB date
Not only is Indigo treating FEB 29 as a valid date on years when there is no FEB 29, but the date that it assigns is Mar 1.
So on days like today ALL of your FEB and MAR schedules will BOTH run.
Thu Mar 01, 2018 3:37 pm
makes me wonder what happens if you set something to run on Feb 30. Or Feb 35, for that matter!
Thu Mar 01, 2018 3:47 pm
CraigM offline
The UI won't let you. Feb 30 & 31 are grayed out
Thu Mar 01, 2018 4:09 pm
We make the assumption that the user wants the schedule to run regardless of leap year, so we move it to the next day.
If you want a schedule that only runs specifically on Feb 29th every 4 years, I'm afraid you'll need to take a different approach...
[EDIT] - this is a guess, I didn't actually dig into the code but I'm pretty sure this was intended behavior (Matt can clarify if I'm wrong).
Thu Mar 01, 2018 5:10 pm
CraigM offline
Exactly, I expected it to run regardless of leap year. But when there is no February 29, I would assume it would skip past that date. Why would it run the next day, which is March? That logic escapes me. What is the point of having monthly parameters?
Example of what happened today:
6:00am Turn on IRRIGATION Zone 2 for 10 min [Feb]
6:00am Turn on IRRIGATION Zone 1 for 28 min [March]
8:00am Turn on HEAT and set to 72º [Feb]
8:00am Turn on COOL and set to 80º [March]
Then when you factor in the Lighting, Windows, and every other February schedule getting multiple conflicting commands.
I'm not looking for anything unusual or special solution pertaining to leap year. Just expected a February schedule to run in February.
Thu Mar 01, 2018 5:59 pm
Personally, I agree with the OP that running a Feb schedule in March seems like a bug. On the other hand, I can't grasp the logic of doing those kind of scheduled things based on the calendar month. Season, yes. School year/holidays, sure. But just the month? To each their own. ;)
Fri Mar 02, 2018 9:29 am
Take a screenshot of how you have your schedule defined and attach it to a reply.
Fri Mar 02, 2018 9:30 am
CraigM offline
I live in the desert [32º winter low, 120º summer high] where we have enough changes to temp [HVAC], water needs [irrigation], sun position [window shades & lighting] to warrant monthly changes. Seasonal would never cut-it
Fri Mar 02, 2018 9:42 am
CraigM offline
Fri Mar 02, 2018 1:27 pm
Change your February schedule to remove the end date. Then, add a condition: If current date is between January 31st and March 1st
That condition will ensure that the schedule only executes it's actions in February (between is not inclusive). And it should cover any date in February even if it's leap day.
