indigo utilities discussion
Re: indigo utilities discussion
Yes that’s an option.
But then you get ts twice.
Can do that if you prefer.
Would be nice to have do
ts-local and * but not ts
Have not found how to do that
is this better?
utilities print SQL data for device 375541516/wind sensor states: ['*']
SQL command= /usr/bin/sqlite3 -header -column '/Library/Application Support/Perceptive Automation/Indigo 7/logs/indigo_history.sqlite' "SELECT id, strftime('%Y-%m-%d-%H:%M:%S',ts,'localtime') as 'ts_local' , * from device_history_375541516 WHERE ID > 0 ORDER by id LIMIT 5;"
SQL-OUTPUT:
id ts_local id ts onoffstate avgspeed batterylevel directiondegrees directiontext display gust lastupdated signalstrength temperature type windchill
2 2014-06-28-11:45:32 2 2014-06-28 16:45:32 False
3 2014-06-28-11:45:48 3 2014-06-28 16:45:48 0 0 0 0 0 0 0 0
4 2014-06-28-11:45:58 4 2014-06-28 16:45:58 4.9 10 0 N 4 mph 2.7 2014/06/28 5 0 2 0
5 2014-06-28-11:46:12 5 2014-06-28 16:46:12 3.4 10 0 N 3 mph 2.7 2014/06/28 5 0 2 0
6 2014-06-28-11:46:40 6 2014-06-28 16:46:40 3.4 10 0 N 3 mph 6.9 2014/06/28 5 0 2 0
- Colorado4Wheeler
Hey, anything you do in regards to getting the system date displayed is A-OK with me Karl! That looks awesome, thank you!!
- Colorado4Wheeler
Oh and there isn't a way to exclude a column from * through a query. The alternative would be to copy it to another table and report that (SELECT * INTO plugin_output and then DROP COLUMN) or to do a quick field check beforehand so that when the user selects * you interpret that as looping through all fields except TS. I'm an SQL developer and have been down this path before.
It is easier to do this on the result in python
this https://www.dropbox.com/s/7q2wgce1eexuk ... 0.zip?dl=1
will produce this:
for sqlite
is this ok ? if yes will post to GitHub
reformatted the output in python (drop col 2, swap col 0,1)
will produce this:
SQL command= /usr/bin/sqlite3 -header -column '/Library/Application Support/Perceptive Automation/Indigo 7/logs/indigo_history.sqlite' "SELECT strftime('%Y-%m-%d-%H:%M:%S',ts,'localtime') as 'ts_local' , * from device_history_375541516 WHERE ID > 0 ORDER by id LIMIT 10;"
SQL-OUTPUT:
id ts_local onoffstate avgspeed batterylevel directiondegrees directiontext display gust lastupdated signalstrength temperature type windchill
2 2014-06-28-11:45:32 False
3 2014-06-28-11:45:48 0 0 0 0 0 0 0 0
4 2014-06-28-11:45:58 4.9 10 0 N 4 mph 2.7 2014/06/28 5 0 2 0
5 2014-06-28-11:46:12 3.4 10 0 N 3 mph 2.7 2014/06/28 5 0 2 0
6 2014-06-28-11:46:40 3.4 10 0 N 3 mph 6.9 2014/06/28 5 0 2 0
7 2014-06-28-11:46:54 3.4 10 0 N 3 mph 5.6 2014/06/28 5 0 2 0
8 2014-06-28-11:47:08 4.7 10 0 N 4 mph 3.6 2014/06/28 5 0 2 0
9 2014-06-28-11:47:22 4.7 10 0 N 4 mph 4.3 2014/06/28 5 0 2 0
10 2014-06-28-11:47:36 4.7 10 0 N 4 mph 5.4 2014/06/28 5 0 2 0
11 2014-06-28-11:48:04 4.9 10 0 N 4 mph 6 2014/06/28 5 0 2 0
utilities record id# 0 2 2014-06-28-11:45:32 False
- Colorado4Wheeler
Genius! Looks awesome!
posted the final version on GitHub. Had to add code for "no header and/or no separator"
The trick to drop the regular TS column does not work if there are no columns in the output and no separator to id the columns (one of them is ok)
This is only for sqlite db and selection =*.
Time was already local for selection with specific columns and all of postgres
- Colorado4Wheeler
LOVE! Thanks Karl, it makes the report a lot more useful for me!
SQL-OUTPUT:
id ts_local sensorvalue
1 2018-01-08-09:16:30 335.0
2 2018-01-08-09:17:11 335.0
3 2018-01-08-11:13:08 18.0
4 2018-01-08-11:13:31 376.0
5 2018-01-08-11:17:34 15.0
6 2018-01-08-11:18:03 371.0
7 2018-01-08-11:30:01 25.0
8 2018-01-08-11:30:31 362.0
9 2018-01-08-12:33:42 29.0
10 2018-01-08-13:31:51 378.0
11 2018-01-08-13:32:13 14.0
12 2018-01-08-14:32:51 229.0
13 2018-01-08-15:33:28 238.0
14 2018-01-08-16:34:06 221.0
15 2018-01-08-17:34:45 214.0
16 2018-01-08-18:35:23 216.0
17 2018-01-08-20:36:40 217.0
18 2018-01-08-21:37:20 218.0
19 2018-01-08-22:38:02 219.0
20 2018-01-08-23:12:44 0.0
21 2018-01-09-08:00:18 392.0
22 2018-01-09-09:00:19 186.0
23 2018-01-09-10:00:56 81.0
24 2018-01-09-11:01:35 22.0
25 2018-01-09-12:02:16 26.0
26 2018-01-09-13:02:52 21.0
Glad it works for you.
released v 1.14.11
added option to print all indigo store plugins sorted with latest release date
looks like this:
looks like this:
Plugin Name web page ----------------------------------- Date released Version
piBeacon https://www.indigodomo.com/pluginstore/59/ Jan. 29, 2018 7.80.201
Sensibo https://www.indigodomo.com/pluginstore/146/ Jan. 29, 2018 0.1.5
NuVo Grand Concerto https://www.indigodomo.com/pluginstore/66/ Jan. 28, 2018 2.0.2
FindFriendsMini https://www.indigodomo.com/pluginstore/139/ Jan. 27, 2018 0.4.9
Multitool https://www.indigodomo.com/pluginstore/145/ Jan. 25, 2018 1.0.14
fingscan https://www.indigodomo.com/pluginstore/72/ Jan. 23, 2018 7.24.21
Announcements https://www.indigodomo.com/pluginstore/141/ Jan. 19, 2018 0.4.0
Shairport Sync https://www.indigodomo.com/pluginstore/144/ Jan. 18, 2018 1.0.0
Eversolar Monitor https://www.indigodomo.com/pluginstore/143/ Jan. 17, 2018 1.0.1
NetworkOwl https://www.indigodomo.com/pluginstore/142/ Jan. 16, 2018 1.6.1
Mac Apps https://www.indigodomo.com/pluginstore/92/ Jan. 14, 2018 0.0.6
Whilst you have an option in utilities to output device names and ids to the log, it would be awesome if you could output the same to a postgres table as well, ie something with 2 columns, device_id, device_name? Or even do a generic one, so has columns of id, name and type, where type is device or variable?
You mean creating a table in the indigo Postgres database? I would shy away from that. Indigo owns the dB. I don’t know what indigo would do if another tables is created.
Yes I did... although indigo owns the database indigo_history or whatever its been called, what about creating in the postgres db, or the username one?
Or I guess I could run it in a script, with a quick hack of asomethign found online, something along these lines?
import psycopg2
conn = psycopg2.connect(database = "userid", user = "postgres", password = "", host = "127.0.0.1", port = "5432")
cur = conn.cursor()
cur.execute('''CREATE TABLE DEVICES
(DEVICE_ID INT PRIMARY KEY NOT NULL,
DEVICE_NAME TEXT NOT NULL);''')
conn.commit()
for dev in indigo.devices:
cur.execute("INSERT INTO COMPANY (DEVICE_ID,DECIVE_NAME) \
VALUES (dev.id,dev.name )");
as as starting point?
import psycopg2
cur = conn.cursor()
conn.commit()
