new plugin input request
Wed Aug 10, 2016 11:26 am
Re: new plugin input request
Just ran across this on Reddit. YeeLights has opened up their API. And apparently it doesn't suck.
Wed Aug 10, 2016 1:44 pm
Gusten offline
How about a plugin for withings wi-fi scale?
Thu Aug 11, 2016 1:46 am
Wifi scale: To get the bad news electronically??
will look at it.
Thu Aug 11, 2016 3:18 am
This will challenge my command of Mandarin!! - ordered one, delivery is in September
will also look at: https://lifx.readme.io/
Thu Aug 11, 2016 6:07 am
autolog offline
kw123 wrote:
... will also look at: https://lifx.readme.io/
There is already a LIFX plugin available (see signature below) that doesn't rely on having the internet available to control your LIFX lamps - posted in case you weren't aware :)
Thu Aug 11, 2016 8:28 am
Asconasny offline
what about Milight
http://www.milight.com/
Regards
Asconasny
Thu Aug 11, 2016 9:28 am
.. yes thanks.. and nicely written can learn something
Fri Sep 09, 2016 5:08 pm
Tue Feb 06, 2018 9:11 pm
would like to open it up again... I am kind of done with my big plugins. Little things here or there that might be added..
One of my ideas is to use an RPI to do voice commands. That would not require any internet connection like ALEXA
any other suggestions?
Wed Feb 07, 2018 5:34 am
norcoscia offline
Karl, would that be speak or only take commands - except for Sonos there is no way to do speech w/o hardwiring your house - the BT stuff just does not work reliably .
_______
Norm
Wed Feb 07, 2018 7:13 am
How about a zigbee dongle plug-in?
Wed Feb 07, 2018 7:32 am
Asconasny offline
+1
Plugin for something like this maybe
https://www.dresden-elektronik.de/funkt ... spbee/?L=1
Wed Feb 07, 2018 7:58 am
Carnegie melon has a library that runs on rpi. It can be used to recognize words Then after recognition any Unix command can be executed.
The goal would be to setup a system that allows users to train the rpi, link words like “switch light on” to a script. That would travel to indigo and then an action can be executed.
Wed Feb 07, 2018 8:29 am
norcoscia offline
So the RPI would not be able to make announcements?
_______
Norm
