Getting time of last update from RFXCOM device
Sat Jan 27, 2018 2:38 am
davinci offline
I have a temperature sensor (new KaKu) that I included by RFXCOM. On the device in Indigo I see the time when last updated. How can I get this time in Python?
This doesn't seem to work since the term is not in dict...
time= sensor.states["timeOfLastChange"]
Sat Jan 27, 2018 4:40 am
autolog offline
Re: Getting time of last update from RFXCOM device
Try the following:
time = indigo.devices[12345678].lastChanged
# or
time = indigo.devices[12345678].lastSuccessfulComm
where 12345678 is your device Id (change as appropriate) :)
Sat Jan 27, 2018 10:00 am
davinci offline
Unfortunately it doesn't work either:
AttributeError: 'Dict' object has no attribute 'lastSuccessfulComm'
AttributeError: 'Dict' object has no attribute 'lastChanged'
Sat Jan 27, 2018 11:35 am
autolog offline
That's odd :?
Can you post the code before and after the failing statement so I can get a view of what you are doing? :)
Sat Jan 27, 2018 11:41 am
autolog offline
Even better could you post the results of running the following embedded python script:
indigo.server.log(u'RFXCOM Device: {}'.format(indigo.devices[12345678]))
where 12345678 is your device Id (change as appropriate).
This will give a view of your device that will confirm what the command should be. :)
Sat Jan 27, 2018 11:51 am
this works for me:
dev =indigo.devices[719674580]
indigo.server.log(unicode(dev.lastChanged))
Sat Jan 27, 2018 11:54 am
I don't think you are using the code exactly as autolog pasted it above. It looks like you are trying to access the device's state Dict, but he is referencing properties that are built into the device instance.
Sat Jan 27, 2018 12:00 pm
davinci offline
Thank you all!
This works:
I'm not sure anymore what code I had before but with dev it works. What is the difference by the way?
